Relentless tuning v4 manifold k04
crack5111 Jun 26, 2014
  1. crack5111
    crack5111 New Member
    here is the v4 manifold which i have been lucky enough to get my hands on and be one of the first.Looks very good and a nice bit of kit and i'm looking forward to getting it on the car and seeing what it can do and how it performs and fits etc.
    I will be doing a build so I will put pictures up of my work in progress and will show you and tell you what it's like to fit etc.
    i shall keep you all updated as and when.
    Here is also a link to the relentless manifold page for you all to check out:
    https://www.facebook.com/groups/125246960928520/?fref=nf
    sportquattro and mark_S3 like this.
  2. Screwwheypusher
    Screwwheypusher New Member
    19
    Was thinking of buying one of these, how did you get on with the fitting / performance and reliability?
  3. daz-20vt
    daz-20vt Well-Known Member
    2,828
    580
    loads of people using these inc myself
    no reliability issues as far as im aware
    gains are good but what level of tune are you at fella?
  4. Screwwheypusher
    19
    AMK engine with
    Forge turbo intake pipe
    Forge short shifter
    Itg panel filter
    Dogbone mount
    Joe power remap 240 bhp
  5. daz-20vt
    2,828
    580
    are you planning on going any further with it?
  6. JonnyDerv
    JonnyDerv Active Member
    419
    72
    Forge tip is tapered isn't it? Get a badger5 one.
    I'd look into fmic and downpipe before a manifold
    daz-20vt likes this.
  7. daz-20vt
    2,828
    580
    pretty much word for word what i was going to say
    should have just said it and not been so cryptic haha
    still would like to know as if your going to stage 2 etc rods may be needed
  8. JonnyDerv
    419
    72
    Perhaps, were long lost twins :| I've missed you bro!
  9. daz-20vt
    2,828
    580
    you must be the good looking one lol
  10. JonnyDerv
    419
    72
    I'm not gonna argue with that ;)
  11. <tuffty/>
    20,998
    3,764
    I wouldn't either... I've met him LOL
    Much love Daz ;)
    JonnyDerv, Alex C and daz-20vt like this.
  12. Screwwheypusher
    19
    To be honest lads, bought the car about a month ago and there's a crack in the oem mani. At the moment no plans to go further with tuning but keeping an open mind!
  13. daz-20vt
    2,828
    580
    unless its blowing id leave it.the manifold isnt the easiest job in the world and as you are i wouldnt count on much on the way of gains
    JonnyDerv likes this.
  14. Screwwheypusher
    19
    The noise is wreckin my head!
  15. JonnyDerv
    419
    72
    It's a head off job, if you do it you might as well do rods at the same time
  16. Screwwheypusher
    19
    :flushed:Is that a big job?
  17. daz-20vt
    2,828
    580
    you can do it from below
    you need to remove sube frame and transfer box i believe so you may aswell do hybrid and downpipe lol
  18. Screwwheypusher
    19
    May as well go milltec and fmic as well ha ha!
  19. <tuffty/>
    20,998
    3,764
    Are you sure its the manifold? K04 manis are rubbish granted but rare for them to crack enough to blow (not unheard of just rare)
    Typically a blowing noise is either the manifold/turbo gasket where the bolts have relaxed a bit and come loose, this then compromises the gasket and it blows... the threaded inserts can also back out a bit on K04's so those need to e checked before refitting a new gasket if this is the issue...
    The other cause of a blowing noise is the EGT probe backing out... this is located in the back of the turbo's hotside..
  20. Screwwheypusher
    19
    Mechanic has had a look at it already and replaced the waste gasket - a new one was supplied with the car he,had the turbo out because one of the bolts sheered when he was disconnecting from mani. When he did that there was none there to start with so he thought that that was the problem. Put it all back together and noise is still there. Definitly exhaust gases escaping somewhere (can smell them) and he said he'd take the mani off and inspect it when he has a chance. He also looked at the manifold bolts when he was at it and they all appeared to be fine.
  21. <tuffty/>
    20,998
    3,764
    Did he use new bolts? as in all three? did he check that the inserts were flush before refitting? has he checked the EGT probe as you haven't mentioned that yet?
  22. JonnyDerv
    419
    72
    Underneath is gonna need subframe drop, turbo removal etc etc, it is a big job to remove the manifold
  23. Screwwheypusher
    19
    He defo replaced all three bolts, not sure if he checked EGT! Might mention it to him when he gets it again. Would this be obvious from a visual inspection or would you have to start stripping it back to see it!
  24. <tuffty/>
    20,998
    3,764
  25. Screwwheypusher
    19
    Thanks Tuffty!
