Relentless manifolds proof god hates us ?,
mclean1988 May 2, 2013
  1. mclean1988
    mclean1988 Member
    32
    Been trying to fit my relentless manifold today and been having a right mare!!
    After having grinded a spanner to its death I think I have final managed to tighten the 9th bolt !!
    I've gone to fit the turbo and see no physical way of getting the turbo bolt through the manifold ??
    Has anyone got any tips from previous experience ??
  2. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    I boy pal that's hard I did it with head off and to me there is no way
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Put a stud in the turbo then use a nut...
  4. Broken Byzan
    13,237
    465
    did you remove a ferw mm off the top edge of the flange to prevent it fouling the head casting, all of the ones I have seen don't fit without modification
  5. s3dave
    10,110
    736
    And take a chunk out of the downpipe flange,, on the top hole
  6. mclean1988
    mclean1988 Member
    32
    Is studding the turbo the only way to get them to fit ??
  7. jezzy
    jezzy Member
    768
    Hi mate
    Yes studding the turbo to manifold with the relentless manni is the only way.( mines a v2)
    The bolt next to the head you can get away with, the other two you cannot.
    You will need to cut a couple of mil of the other two studs to get the nuts on.
    I got my studs and nuts from tps.
    Buy a couple of extra nuts for the studs, the fall down the back of the engine and are hard to find.
    Make sure you bolt the turbo support bracket up or this could happen.
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187191-v2-cracked.html
    Good luck
  8. mclean1988
    mclean1988 Member
    32
    Thanks for the reply , any idea on what size and length stud I need ??
  9. badger5
    9,578
    2,040
    its m10, often use downpipe studs as the stud.
