Releasing a few horses from 1.8T 190
shaunmc Jan 18, 2011
  1. shaunmc
    shaunmc New Member
    29
    Hi, ive got a B6 1.8T 190 and im interested in a silicone induction hose as all the ebay links say they help improve bhp, i can find plenty for lower spec 1.8T engines, are they all the same for the engines or would there be different ones for different hp models?
    Im only asking as there are some from china, that are very cheap (obviously the quality may show) and some from say Forge, that seem very expensive.
    Also, im interested in being able to hear a 'Dump/BOV' noise from my car when changing gear, will a basic aftermarket diverter valve achieve this? as i dont really want to buy an open air filter or Carbonio airbox, as i dont want to change the look under my engine bay.
    All advice/comments welcome
    Shaun
  2. hades-
    9,481
    646
  3. Nutkin
    Nutkin Member
    830
    Check and rolling road your car first to make sure its in top condition, ive spent a good few quid getting my 190 to 190!!!
  4. CHRIS555
    CHRIS555 DOPE with added OCD
    1,969
    10
    Most of the silicon hoses on ebay are China specials and I wouldn't put one on my car. I do get the whoosh noise your after but I needed a Carbonio to get it right.
    If you have not already done it, remap your car - it's the best bang for bucks going.
  5. aragorn
    18,020
    716
    Leave the chav-valve alone, it just screws up the fuelling. Its an Audi, not a Saxo.
    Reputable remap really is the best place to spend you money.
  6. BahnStormer77
    BahnStormer77 BahnStormer
    2,757
    54
    I'd second the Rolling Road before you screw around with anything else - best £50 you can spend!
    "I" identified a failing fuel pressure regulator with a quick RR and released an extra 20bhp with a quick fix.... and that was on a NA car!!
    edit: Chip'N'Spin are doing their RR day on 26-FEB: £250 for a pre-RR, remap and post-RR. Hopefully they're stll doing this, but in the past, if they've found any probs (turbo probs, boost sensor / airflow meter problems, etc), they just charge you for their RR session and print outs (£50).
  7. shaunmc
    shaunmc New Member
    29
    Thanks for the advice everyone.
    Got in touch with a mate who knows someone with a rolling road, so hopefully will get it booked in asap.
    So you say any silicone induction hose from the 163 will fit my 190?
    Ill see about the re-map after the rolling road etc.
    On 10 days off now so im getting my windows tinted, blacking my grills, changing numberplate bulbs and possibly interior ones too.
    Shaun
    EDIT: Found this silicone induction hose on ebay, looks pretty reasonable, theres one for closer to £200, but it actually looks cheaper than the one pictured. I dont like the fact that its blue, is it possible to spray silicone black?
    AUDI A4 VW PASSAT B6 1.8T AIR INTAKE PIPE SILICONE on eBay (end time 21-Jan-11 10:49:52 GMT)
    Heres the £200 one, which one looks better?
    1.8T 20V Intake Kit 98-05 Audi A4 / Passat on eBay (end time 03-Feb-11 15:57:58 GMT)
  8. BahnStormer77
    2,757
    54
    make sure you get a RR session where the fuel mix is being measured, even better if it links into the OBDC and can tell u the boost level, etc.
  9. Nutkin
    Nutkin Member
    830
    i can tell you now my 190 is making 120 :D
  10. AU01 A4
    AU01 A4 Member
    211
    Come on, it cant have lost that much, have you remove the turbo
  11. Nutkin
    Nutkin Member
    830
    I have no idea, goes into a garage for a week tomorrow.
    I had the DV cleaned (baileys) and the N75 changed still not boosting right. Turbo spools can hear it so your guess is as good as mine, just gonna check hoses for leaks tbh.
  12. AU01 A4
    AU01 A4 Member
    211
    could you have a leak in the intercooler or a connection to the intercooler, if you dont find any leaking pipe
  13. shaunmc
    shaunmc New Member
    29
    I wouldnt have thought cleaning a dump calve with baileys would do any good :p
    Can anyone spread a light on the 2 above induction hoses? just curious as i have the money waiting
    Shaun
  14. Nutkin
    Nutkin Member
    830
    I personaly dont think it is worth it until you get the map and then i'd probably just grab the forge tip as its tried and tested. although gt3 turbo is a reputable site.
  15. AU01 A4
    AU01 A4 Member
    211
    The 190 have twin intercoolers, small ones behind the fog lights
