relays for interior lights
va4o__ May 8, 2012
  1. va4o__
    va4o__ New Member
    Hello! I have Audi A4 B5 1999 My question is one, precise and specific. Can anyone tell me what relay is responsible for the interior lights and a relay which is responsible for electric mirrors and where are these relays.
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Most relays are on the drivers side, under the steering wheel.
  3. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    Most issues are down to the c/l pump which is the control unit for them
    I might be wrong but I don't think there's any actual separate relays for them
  4. aragorn
    18,016
    714
    yeh, CL pump acts as the relay for interior lights and windows etc.
  5. murran
    murran Well-Known Member
    1,545
    39
    pull the central locking pump out. you'll most likely find it sat in a puddle of water.
  6. jonnycraig
    jonnycraig Member
    157
    Totally agree.... the sponge thing covering the CL pump will also hold a lot of water so might be useful to take it out and dry it. Caused my car to do weird things, flash indicators, pop the locks open by themselves after locking.
    I popped off the lid and found corrosion on the board, cleaned it off and now works properly.
  7. ScottD3
    15,161
    1,121
    How does water get in to this area?
    Mine's been a bit damp recently.
  8. va4o__
    va4o__ New Member
    Look, i ask for these relays because my electric mirrors dont work and the interior lights dont work when a door is open. So i decide that the relays are broken.
  9. B5 BIKER
    B5 BIKER Member
    266
    OOOH!!!
  10. Sulli79
    Sulli79 Active Member
    541
    37
    As people have said there are no relays as such, there is a circuit board in the CL pump that controls everything and you need to check it. Failing that check your door looms for shorts or breaks.
  11. murran
    1,545
    39
    ok, we admit it, were trying to send you on a wild goose chase.
    the relays you speak of are inside the n/s/f tyre.......
    the air pressure and g forces of the wheel turning at high speed causes the relays to fail.
    you need to remove the tyre and fit new ones. once fitted, to stop it happening again you need to remove the center of the tyre valve (core) and fill the tyre with expandafoam then refit the valve core.
    i cant garantee this will fix it but its a good place for you to start!
