relaced cv boot now i have a noise at 35-40 mph A4 B5 2.6 v6
daz616 Jul 2, 2010
  1. daz616
    daz616 Member
    37
    i have just changed the front offside cv boot on my a4 b5 2.6 and now when i get to 35-40 there is a rumble which gets worse when you speed up and let off the throttle now im thinking i have disturbed the wheel bearing when i took the drive shaft out anyone had this problem before
    thanks in advance
  2. aragorn
    17,889
    689
    didyou retighten the bearing correctly?
  3. daz616
    daz616 Member
    37
    i didnt take the bearing out only the cv joint
  4. adesb5
    adesb5 Member
    34
    did you regrease the cv? it might have a load of **** in it if the boot had split
  5. daz616
    daz616 Member
    37
    i did grease it but im going to take it off again and pack it again just incase i missed somthing
  6. aragorn
    17,889
    689
    You need to unbolt the bearing to remove the CV....
    The bearing needs tightened to about 200NM, so have you tightened it correctly?
  7. adesb5
    adesb5 Member
    34
    that answers a question i was gonna ask about 150ft/lbs in old money then? as ive gotta do one on my 1.8tq but it seems ive got v6 driveshafts as its got 30 teeth on the shaft
  8. daz616
    daz616 Member
    37
    i would say i havent i just did the hub bolt up with a breaker bar
  9. aragorn
    17,889
    689
    well to be fair, the tightening instructions are something like "tighten to 90nm then 180 degrees" and i've never managed to get the full 180 degrees yet.
    So as long as you hoofed it up as much as you could with a breaker bar you're most likely fine.
    Adesb5: all TQS's have 85mm front bearings and the larger CV joints.
  10. adesb5
    adesb5 Member
    34
    aragorn mate thats what i ordered but didnt fit the shaft, fitted the hub,after a little investigation it was found to have 25mm shaft with 30 splines which is what the v6 cars should have so ive been told.numbers on the shaft are 8do 407 272 ah/ j2 ah if that meens anything to you shaft seems to have been there from new it dont look like its been touched, date after the barcode is 14/4/99,all i know is the one for the 1.8tq dont fit,but then again it dont meen the shaft aint been changed at some time in the past.
    cheers fella
    adie
  11. daz616
    daz616 Member
    37
    right bit of an update took the shaft back out regreased both cv joints put back on took for test drive still got the rumble then took it out of gear and the rumble stops !! think it might be the gearbox not good !!
