Refurbishing gear linkage
cerips Aug 9, 2010
  1. cerips
    cerips Member
    54
    Has anyone got any experience of refurbishing their gear linkage?
    I suspect mine is due some TLC as the car has clocked up nearly 183K!
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Is it pre facelift or facelift as they are not the same. I found a place in the states that do a metal bush to replace the rubber on facelift ones. I want it done on mine.
  3. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    the 'ebay' quick shift works quite well, but as my kit didnt come with instructions i found it easier to use a later facelift mechanism that didnt have a push down reverse rather than work out how to attach spring etc.. wasnt sure it would even work but it did
    so i now have a very nice precise feeling gear change and less moving parts
    not sure why my facelift tqs has an earlier type push down reverse when other facelifts dont though?
  4. cerips
    cerips Member
    54
    Sorry should have said it's a facelift 6 speed box, although mine also has a push down reverse as well.
  5. olds_kool
    1,089
    13
    ah, my tdi is the same and now feels very sloppy in comparison (200k+), the quickshift will work on the six speed and actually bought it for that car but couldnt work out how to fit it !
  6. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    you can usually buy a kit from audi to refurb the linkages.
    they do them for golfs anyway
  7. ian52
    1,199
    On mine its the bush at the gearbox end thats shagged and that means buying that whole arm at something like £70
