Refixing S-line badge - what to use?
munchkincoupe Oct 9, 2010
  1. munchkincoupe
    munchkincoupe Member
    948
    19
    Some little scr*te has attempted to steal one of my side strip s-line badges today. Luckily not damaged the bodywork but they have bent the badge. I'm not going to be able to straighten it without taking it off. Before I do I need to know what adhesive product to re-back it with so it sits the same as before and won't fall off even if receiving a little persuasion!
    Thanks for any advice
  2. jimmy77
    jimmy77 Member
    102
    little tw##s!! just remove it,you might need to cut with knife and remove the double sided tape and use new double sided tape mate,you can get it on rolls but its expensive or if you have any just use mirror double sided sticky pads and trim to size!!!
  3. munchkincoupe
    948
    19
    What's the strongest double sided brand you can get without damaging the paint surface?
  4. jimmy77
    jimmy77 Member
    102
    errrm, well i use either 3m or some stuff in a red box which i cant remember the name!!! heat it up with a heat gun and it will stick better,if you have some use thinners or your mrs nail varnish remover to clean the bonding surfaces first!! you wont damage the paint with the sticky stuff!!
  5. munchkincoupe
    948
    19
  6. johnnythepie
    johnnythepie Well-Known Member
    2,242
    76
    Hmmmnn.difficult one that.If you think that the pondlife will be back, Id be tempted to use something that wouldnt take a massive effort to remove.That way youll only lose the badge.If its stuck on really well, they might use a screwy/blade to remove it, then you have no badge and body damage.God id love to catch em at it.
  7. munchkincoupe
    948
    19
    It happened whilst car was parked at the Trafford centre so shouldn't happen again. I parked in a cr*p spot too!
    I tried the only 3M tape I could find near me but it was too thick once stuck on so I removed it again and used the double sided number plate tape from Halfrauds - looks the same as other side now
    Thanks for replies fellas
