Refitting Puddle Lights
chrisb72 Nov 26, 2011
  1. chrisb72
    chrisb72 Active Member Team Panther Audi S3
    231
    68
    I am trying to upgrade my Puddle Lights to LEDs and I'm having what seems to be a common problem with the length of the wire.
    I have managed to pull the bulb holder out of the door panel and have fitted the LED bulb, but now I am struggling to fit the holder back into the connector.
    I have read various threads including ones that say remove the door panel, but I'd prefer not to do this if possible! I can only find instructions to do this for later models and I have a 2006 Sportback which seems to have a different panel to what was illustrated in the thread.
    I did hear of someone just pulling the bottom of the panel slightly to get at the light, but it didn't say what to do them??
    Can anyone help me please, before I rip all my fingers to bits!!!!
  2. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    1,977
    692
    undo the torq screw at the bottom of the door card, then pull the bottom of the door card off the door so you can get your hand in behind and connect the lamp unit back in, or you can undo the clip that is holding the wire back to loosen it up.
  3. chrisb72
    231
    68
    Ok thanks that seemed to help and I have now done drivers door. Now how do I get the rear door panel off in the same fashion as I can't find any screws to undo.
    Hopefully the passenger side will be easier now I have mastered this technique!
  4. chrisb72
    231
    68
    Okay I've managed to prize open the rear panel BUT.......the light stop working!
    Ive checked the bulb and its not faulty. I suspect I've caught a cable or something as the Red light was working, but after more fiddling now that has stopped working!
    I'm stopping this job before I do any more damage.
    Help please?
    Have undone a connector somewhere? I've had a good feel around, but it's not obvious.
    There is a reason why I don't do mods and this is why!!!!!
  5. t8ups
    1,977
    692
    is the standard bulb working in there chris?
  6. chrisb72
    231
    68
    NO.
    It stopped working as I pushed my screw driver under the panel trying to prize it open!
    Red light now working?!
    I've managed to fit all the bulbs now including the other rear door, but this one is still giving me trouble??!!
  7. drnutta
    drnutta Member
    371
    I encountered this... But all it was the car cuts power to save battery after a while.
    If you turn the car on off again do the lights come on?
  8. chrisb72
    231
    68
    Been out in the car and it still not working.
    It's dark now (the other 3 look great by the way) so I will need to wait until it's light again to do any more tinkering. I just hope my attempt hasn't caused too much damage!
    Is there another connector in the the door that could have come loose? I tried following the cable, but without much success
  9. chrisb72
    231
    68
    I'm probably not going to get chance to look at this problem again for a few days, but some helpful advice would be very appreciated.
    Chris
  10. t8ups
    1,977
    692
    Chris i think they run on the same loom, if the red light is working then i dont see how you could of pulled a cable out to stop this from doing it. try a working puddle light in this door to see what it could be.
    Trups
  11. chrisb72
    231
    68
    Thanks for the advise
    I won't get chance to check again now for another week as I'm busy with work in the daytime, but need to try and get the panel fully off (I was having BIG trouble doing so as i couldn't work out how it came away at the top of the door)
    Thinking back though I seem to remember the puddle light stop working the moment my screw drive when behind the panel, but still attached the the door making me worry I've damaged the wire?!
    I will do a bit of investigating and let you know.
    On the matter of the door panel. Which dirrection should I be pulling on the panel once all the pop clips have been undone on the bottom and the sides? I really felt I was going to break something so I just opened it up as far as I could, but I think I would be able to sort this problem easier with it completely off!
  12. chrisb72
    231
    68
    Well I finally managed to find some time to have another play with my puddle lights and I'm pleased to say I have now got the rear one sorted so all four LEDs are kicking out lots of light!
    I don't think the LED bulb was connected properly although I did have trouble getting the original bulb to fire up at one point. With a bit more time and less haste I got to the bottom of the problem and am now very happy with the end result.
    I'm just now thinking how long will it be before I want all the interior bulbs to be LEDs now I'm getting used to the bright WHITE light!
