Reesy's Big Turbo A3
Reesy Dec 1, 2011
  1. Jason.s
    Jason.s Active Member
    2,879
    348
    How longs the wrap been on the downpipe? That smokes pretty badly when hot on its first run fitted.
  2. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    It's progress, and I could have driven it home if I really needed it, but I don't..
    Car had a wash on New Years Day and one in about Mid Feb, so not due one for a few weeks I don't think..
    Hadn't thought of that.
    It's only done about 10 miles, so could well be that. Car smoked a bit when it was put on the old downpipe, although the coolant leak didn't help that..
  3. Westy
    Westy Well-Known Member
    17,443
    1,104
    Why don't you buy some new mounts instead of sealing them? Another pair of stock ones are cheap.
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    nearly there then Reesy , exhaust related work and they smoke like ****...Until its all burnt off
  5. Reesy
    3,640
    148
    i know mate, just a bit of a worry when you have nearly had a fire..
    Wesyy, tiger sealing the spares is easier and should be a bit firmer..
  6. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    Extending life of the spares? Good idea if you have spares to try out. Worth a shot
  7. Reesy
    3,640
    148
    i think the tiger sealed ones are a better option, I can only imagine the strain on the mounts when the turbo comes on boost.
  8. Reesy
    3,640
    148
    So by all accounts the car is back together and ready to race.
    Got to say another massive thanks to Ben. Some knob in a BMW got stuck on a hill yesterday due to havy snow, so my normal 1/2 hour journey home took 2 and a 1/4 hours. Whilst I was sat in traffic in a *** Zafira, Ben sorted out my car for me, again.
    He also told me that the handbrake is seized on. What a treat.
    Car has been heat shielded using some heat mat stuff, but it ideally needs a bit more. Ben thinks the dp was rubbing on mani causing the noise, so he has fixed that and made a bracket to hold the exhaust up at the back of the subframe as it was sitting a bit low.
    the climate control, which didn't work on my test run, was just a fuse as Ben expected. Apparently the rear brake is a bit sticky, but its been released for now. Have heard of people using the Sharan(?) springs to aid this, assuming its not a slightly seized rear calliper.
    Hopefully collect it tomorrow after work. :arco:
  9. Jason.s
    2,879
    348
    My n/s/r caliper sticks with handbrake on when its cold. Only that one though so if i know its going to be freezing i`ll just bring it up 3 clicks instead of 4 and leave it in gear and its fine. Pain though if i forget or dont know if its that cold.
  10. Reesy
    3,640
    148
    It's always the n/s/r. That caliper stuck on my last a3, as well as this a3 one and now I'd pretty much guarantee it'll be the same on the s3 calipers.
    I got told to do the same thing, don't pull the handbrake up too much in this weather. *** **** rear calipers
  11. Jay A3
    2,130
    356
    When we had the first snow spell earlier this yr, my n/s/r was seized up. Turns out it was the hand brake cable itself that was the problem. I think it was something like £8 for a new cable. Worth inspecting next time its up on the lift
  12. Prawn
    11,532
    3,471
    my NSR caliper has issues too! wtf is going on?
    Someone going to start a group buy? :laugh:
  13. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
    Who do you call?
    I got nothing else to do lol
    Westy likes this.
  14. Jason.s
    2,879
    348
    Usually me! Ffs lol
    ScottD3 likes this.
  15. Reesy
    3,640
    148
    Sort out a group buy for fuel pumps instead, I'm sure i'll need one in the next few months..:racer:
  16. Jason.s
    2,879
    348
    I do them at staff rate anyway so can't go cheaper lol.
  17. Westy
    17,443
    1,104
    NSR here too. Been squeaking when I reverse slowly too. I assume it's sticking.
  18. dancuz
    dancuz Member
    140
    Yup, NSR squeaks when reversing and loves a good squeal in the wet
  19. superkarl
    superkarl MAN OF STEEL
    9,482
    2,435
    mine is OSR!
  20. jonno123
    jonno123 Member
    99
    mines osr
  21. Reesy
    3,640
    148
    Time for an update:
    Picked the car up Wednesday night. Under load the downpipe was still knocking but I needed the car for Thursday so took it anyway. Driving off boost the car was fine so that's how I had to drive it unfortunately.
    I have ordered some poly resin to try and reduce engine movement and hopefully stop the downpipe rubbing completely. Should be here early part of next week, which is quite exciting.
    yesterday due to a change of circumstances, the downpipe came off again. We could see where the downpipe was rubbing so a strategic dent was put in the downpipe. It was not as severe as a milltek system that Ben had in stock so I'm not too worried.
    The dent has defiantly helped, as it now only knocks when under load and the wheel being turned. Hoping the engine mounts will stop this altogether. Yesterday was the first time in weeks I've driven the car on boost and its still very fast, which is good.
    Ben took the car for a drive, and as soon as he came backin he took the clocks out of my car and removed the bulb so my immob light isn't constantly flashing.
  22. Reesy
    3,640
    148
    Opinions on running 2 OEM DV's vs a forge supersize?
    007p isn't quite cutting it.
  23. <tuffty/>
    21,255
    3,880
    I did consider this but I have already blocked up the DV port on my charge pipe and had no room to accommodate it... there are race cars in the Combe Saloons that run dual 007p's so no reason why it won't work
  24. MIGGZ
    MIGGZ nanananananananan BATMAN
    1,461
    304
    got some nice progress there dude!
    i think nick was planning or testing that
  25. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Why not! Only way to find out
    all I'd say is unless they are identically matched the chances are 1 will always dump before the other which may then just render the other useless. Worth trying though.
  26. superkarl
    9,482
    2,435
    Your supersize not dumping all the boost tuffty?
  27. Jason.s
    2,879
    348
    Do something and sell me your 007 for a friendly rate lol. Need one quickish as im sick of my new OEM unit sounded like im blowing over the top of a bottle constantly.
  28. <tuffty/>
    21,255
    3,880
    Its working fine but was considering trying duel OE to see if there was any benefit... my SS valve doesn't leak and works fine but just couldn't see a nice way to fit them on mine so didn't bother...
  29. Reesy
    3,640
    148
    would do but it's welded on to an ally 90... Could remove it but not sure what state the bottom inlet would be in..
  30. Jason.s
    2,879
    348
    Gash!
  31. Reesy
    3,640
    148
    Long time since I updated in here.
    So basically, almost 3 weeks ago my turbo died.
    Car had been up and running for 8 days and drove fine on the 30 mile outward journey, and fine for about 15 miles of the journey home. At a set of lights I could hear a strange noise, but it was so faint I wasn’t sure what it was. Within ½ a mile I could hear a faint whistling so decided I’d limp it home. I assumed that the charge pipe hose had split, as others have had problems and the noise just sounded like boost escaping.
    Put my foot down just to see what the gauge was saying and the car wouldn’t make over 4-5psi, so i thought it’s definitely a hose somewhere. Took a video, but you can only just hear it so I won’t post it.
    After limping the last 10 or so miles home, up a couple of heftly hills at 30ish mph, i pulled up at home and when turning the car off it sounded like a jumbo jet. Straight away I knew that wasn’t just a hose issue. Took the tip off the turbo, cold side was ice cold as it was making no boost at all, and could see this:
    And lots of in and out play.. bugger.
    So basically I have bought an eBay turbo. This one will get rebuilt by owens and sold on in the near future..
    I’ve been away for just over a week so no progress has started yet, but hoping it’ll be well underway this weekend. Most bets are on oil starvation as the cause of the death of this one, so we’ll see.
  32. badger5
    9,491
    1,999
    what was that turbo suppoed to be? aside from short lived
    Westy likes this.
  33. Reesy
    3,640
    148
    It wasn't supposed to be short lived..
    It was an Owen Developments hybrid, with 3071 internals in a 28 frame.
  34. superkarl
    9,482
    2,435
    oil starvation how?
    what were your feeds like? size wise and routing?
    read on vortex yesterday someone had the same thing.
    last thing i wana do on mine is end up in the same boat.
  35. s3dave
    10,110
    736
    Been reading you dont really need an oil reducer?? didnt put one in mine as it looked to have a small port at the bottom of the inlet on the CHRA
  36. beachbuggy
    1,931
    201
    Oil starvation or too much pressure both equally bad!
  37. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Bloody hell **** luck mate :(
    What's the future plans for the car turbo wise?
  38. <tuffty/>
    21,255
    3,880
    From Garrett's FAQ's
  39. BENJAMIN
    BENJAMIN Active Member
    503
    93
    ****ty eBay feed pipe are my thoughts on this.
  40. s3dave
    10,110
    736
    Interesting Tuffty thanks...;)
