RedDejavu Audi S3 Ibis white BE build thread
RedDejavu Feb 3, 2012
  1. RedDejavu
    RedDejavu Well-Known Member
    1,786
    331
    I'd say bit deeper but less burp on the upshifts/downshifts. Clearly louder/raspier when reved hard but still nothing annoying. Totally quite when cruising around. Wanted it to be tad louder tbh, it has sports cat not fan of a decat.
  2. RedDejavu
    1,786
    331
    New Revo intake on its way, pics to follow once recieved:]
    Revo Steve-W likes this.
  3. RedDejavu
    1,786
    331
    New REVO fitted ages ago. Overall great experience, nice quality, progressive sound, good low end (better then any of the intakes I've fitted), noticed flutter noise between 3-4k revs, LTFT settled down at 9% which is ok and acceptable no throttle angle problems.
    Few pics:
    In regards to the flutter noise I get decided to do some logs and it comes up that fuel rail pressure drops between 3-4k revs which could be down to the fuel pump not being efficient enough so stage 2+ booked in for 19th:D. No problems when running low boost and timing or map is switched to standard settings.
    However just before I do that I decided to fit one of these bad boys and see if I notice any difference:
    Hope you like it!
    Samy boi and warren_S5 like this.
  4. S.
    S. Well-Known Member Team Ibis TFSI Owners Group quattro Audi S3 Manual
    1,939
    499
    hi mate great mods, and pics.
    love the revo intake, and i'm also thinking to switch to that dv.
    when you'll fit hpfp be sure to get rs4 fpr as well as it makes a difference.
  5. ben@amdessex
    ben@amdessex Member
    290
    20
    Sorry to thread hi-jack Matthew. Just a note to readers of the forum, this problem was only an issue on one batch we had made. There was an issue with the second set of tooling that was made, we had a new tool made and all is now fine. Any that had issues were changed FOC.
  6. RedDejavu
    1,786
    331
    No worries Ben! Happy that you guys sorted it out, shame that I were unlucky to have one from the affected batch though as the intake itself was really good, well made and I did like it :(.
    Speak soon!
    ben@amdessex likes this.
  7. RedDejavu
    1,786
    331
    this is what I'll probabably going to look into next however I suspect all this flutter is software related
  8. S3Alex
    10,366
    4,408
    What sort of flutter are you hearing.....?
    Is it part throttle or on lift-off from full throttle,as what you're hearing could be surge related.
    My previous GT3071 did suffer from that,and would cause the boost to chatter a bit under some conditions.....the new one doesn't do this.
  9. RedDejavu
    1,786
    331
    I get fuel rail pressure drop between 3-4k when running aggressive settings thats when the flutter occurs and on the upshift when rev drops to around that region you can clearly feel lag in turbo spool. When running low boost and timing or standard settings all is fine and smooth
  10. S3Alex
    10,366
    4,408
    If you don't already have an HPFP,the midrange pressure drop is down to the pump,and is because it can't supply sufficient fuel at that range.
    The RS4 fuel pressure regulator can help,but is most noticeable with a big turbo setup.
    Lower boost,or less aggressive settings will certainly reduce the fuel symptoms.
  11. RedDejavu
    1,786
    331
    This is why stage 2+ is on the way and booked in for 19th:D. Then if that wont help I'll do the rs4 regulator next
    S3Alex likes this.
  12. S3Alex
    10,366
    4,408
    I think you'll find it makes quite a difference,maybe not so much in top end power,but in midrange torque.
    The uprated pump really does fill out the area where torque drops off with the stock pump,but also after a few days running,the car will adapt and smooth it out some more.
  13. RedDejavu
    1,786
    331
    OK this is it! Finally managed to get up to stage2+! All thanks to AMD Essex who once again made my car even more crazy fast:D.
    Here is some examples why stage 2 sometimes suc ks and can cause disappointment:
    Stage 2 Fuel rail trims:
    Stock settings SPS Stage 2:
    Now after fitting LOBA fuel pump everything looks different and best of all car feels sooooo much better mid range, just wants to go! Shifts are crisp and sharp, even on D mode everything feels like there is more grunt. Great upgrade for every S3 owner.... Stage 3 next?:D
    warren_S5 and S3Alex like this.
  14. S3Alex
    10,366
    4,408
    Thats shows the problem very nicely.
    The Loba,Autotech and APR pumps all do much the same thing in terms of results,and certainly if I was buying an HPFP again,I'd go for the Loba right now.
    I can vouch also for the Autotech,which has been on mine for over 30 000 miles now,with no issues,but the proviso is it should only be installed by someone who can build it in a clean enviroment.
    Mine is running around 500bhp currently,with no signs of the fuelling running out,and the data suggest that mid-high 500s are OK with these pumps.
    The midrange difference with an uprated HPFP is very noticeable.
  15. Dean_T
    Dean_T Active Member
    645
    139
    43
    How did your car do on the rollers?
    Any problems with the DSG or anything?
  16. RedDejavu
    1,786
    331
    they didnt take it on rollers for some reason..:(
  17. RedDejavu
    1,786
    331
  18. mechanic69
    mechanic69 Well-Known Member
    1,158
    420
  19. RedDejavu
    1,786
    331
    Had a problem with the haldex pump and this made me take it off before taking the car to audi however now I consider to get something new.
  20. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,481
    What you thinking of getting bud?
  21. RedDejavu
    1,786
    331
    Has to be BCS powervalve system:)
    mechanic69, stetheo and S3_Mat like this.
  22. RedDejavu
    1,786
    331
    Before the little one comes I just had to buy myself a gift and there it is:). Me v missus 1:0
    Got it fitted last Saturday and I'm extremely happy, Milltek was good but this one is just fantastic. Quality great, lighter and wonderful noise on upshifts. Not to mention OEM quite off boost. Exactly as I wanted it to be! More pics to follow soon
    mechanic69, Marshy and warren_S5 like this.
  23. warren_S5
    7,210
    2,481
    Nice one, be interested to see what you think of it.
  24. Marshy
    Marshy Settled in Audi RS3
    1,352
    468
    Makes me really excited now.
    Hopefully mine should be within a few weeks
  25. RedDejavu
    1,786
    331
    You will appreciate it if your has DSG :)
  26. grchmason
    grchmason Active Member
    764
    238
    43
    Awesome Matt!!!!! Look forward to hearing it soon
  27. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,232
    377
    Nice updates, reading about your HPFP has made think about getting mine upgraded.
  28. mechanic69
    1,158
    420
    Does look like a quality piece of kit, but I'm still intrigued by the valve tronic milltek unit connected into the canbus
  29. Marshy
    1,352
    468
    I'm manual but still excited all the same.
  30. Granta
    Granta Active Member
    293
    62
    first time i came across this build thread matt, interesting read!! that exhaust sounds sweet, i would love to hear it sometime!
  31. RedDejavu
    1,786
    331
    Ok first time during owning my car I managed to get such mpg-s. Its stage2+ with BCS, driving 60-70 steady relaxed driving, never before could've managed more than 32-33... Very pleased and that includes 20 min sitting in traffic too!
  32. BCS Nige
    BCS Nige Site Sponsor Site Sponsor
    194
    193
    43
    Awesome - Dinner and a show :footy:
  33. RedDejavu
    1,786
    331
    no kidding must be the exhaust making such difference as nothing else I've got changed. Well happy with it, thx Nige!
  34. BCS Nige
    194
    193
    43
    Your right - reducing pressure behind the turbo creates greater kinetic energy at the crank - as the energy required to drive gasses through the choked D/P and cat are reduced.
    nige:yum:
    mechanic69 likes this.
  35. Marshy
    1,352
    468
    Looking forward to some of.this Nige
  36. BCS Nige
    194
    193
    43
    Nice one Kev - your systems in build later this week bud :whistle2:
    Nige
    mechanic69 and Marshy like this.
  37. mechanic69
    1,158
    420
    Me 2 next mod on the list after loba pump which comes tomorrow, happy days
  38. RedDejavu
    1,786
    331
    Bought myself another threat however there is a small problem
    2014-08-20 18.20.35.jpg 2014-08-20 18.20.41.jpg 2014-08-20 18.20.44.jpg 2014-08-20 18.20.52.jpg
    Dont know what to do shall I return it or just fit it as is. Its not cheap and I'm very picky with my car always want everything to be perfect. So in two minds however dont mind waiting a bit longer and get a replacement.
  39. mechanic69
    1,158
    420
    Is that the Airtec from the group buy? Wouldn't stand for that, still 500 or 600 quid of your well earned!!
  40. RedDejavu
    1,786
    331
    I called them and send pics so we will see if they happy to replace it:).
