  1. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Hello Gents, overhauling my brakes soon. Going to go for goodridge braided lines all round and vented (but not drilled or grooved) brembo discs (very well priced at gsf). The rear pads I am going to replace with OE ones, however I want to try some performance items for the front. Was looking at EBC RED STUFF pads. Hoping a good performance pad will make a noticeable difference in stopping power. I tried the 312mm upgrade I while ago now using standard oe pads and TBH there wasnt any noticeable difference in stopping power (not taking into account fatigue-as obvo bigger discs would dissipate heat better).....SO, if not red stuff what have you guys used or are using with a 288mm front setup?
  2. Bradderz_1988
    3,982
    261
    I am hoping to go with a 312mm setup on the front with drilled and slotted disc and red stuff pads staying standard size on the rear withe same as front and get some decent brakelines.
  3. aragorn
    18,578
    868
    I'd be looking at DS2500's or Mintex M1144's
    I've never used either, but i've also never heard much bad about either. The M1144 are slightly more road bias than then DS2500's, the DS's will feel a bit wooden for the first few presses.
    I've heard quite a few people say bad things about redstuff and other EBC pads, and as a result would be very wary of running them.
  4. phoenixv6quattro
    1,396
    Fair one, I have heard some great things about the DS2500's! Never tried EBC, and always keen to try knew parts, but if there rep isnt good than i will probo gove them a miss.
  5. AndyC
    AndyC Moderator Moderator
    719
    I would NEVER use EBC pads again..... we see so many that are a problem and dont perform.
    as above DS2500 or 1144 are good.
    I am running Mintex 1155 on the basis the cars heavy, they get better the hotter they get but are totally acceptable from cold.
    worth speaking to Questmead........ they offer all the mintex pads
  6. B5QUAT
    B5QUAT Member
    317
    13
    Same here, used Redstuff Pads years ago because I didn't know any better. They are OK for fast road (but only ok). But did a track day in they and they completely disintegrated and became prett useless within quite a short space of time. Echo the sentiments re 1144s and DS2500s. Used both and found them very good. Used 1155 once and found them excellent but took quite a bit of warming up to get the most out of them. They can squeal quite a bit too when cold.
    The only good thing about Redstuff is they are very low dust so keep your wheels looking clean. (Ha). A Max Power mod if ever there was one.
  7. Oranoco
    Oranoco Well-Known Member
    3,994
    408
    Wouldn't use EBC pads ever again, there's a YouTube clip I posted of my brothers EBC Greenstuff pads smoking like mad losing all stopping power after just 3 or 4 stops.
    Ferodo DS2500 or Mintex 1155 would be my prefered choice, Mintex 1144 are a bit more road oriented
  8. gmx
    gmx Member
    148
    Where do you guys shop for Mintex pads?
  9. AndyC
    719
    Questmead
    Ask for Alan, say Andy from Ktec sent you.
  10. AndyC
    719
  11. aragorn
    18,578
    868
    Website looks to be trade only?
  12. AndyC
    719
    ah sorry.... you can get them via me in that case...
    drop me an email with what you need
    ecutuner@hotmail.co.uk
    will check prices and availability.
    the site has just changed.... so perhaps retail sales have been dropped for their suppliers.
  13. phoenixv6quattro
    1,396
    Going for the DS2500's. Thankyou very much fellas!
  14. bmarshall
    bmarshall Member
    The redstuff dust a lot too. I like them for road though. I use the tyrol sport stiffening kit
