Recommend my next mod!
Els Apr 23, 2010
  1. Els
    Els Member
    80
    Hi chaps,
    I need more power lol but maybe I should upgrade the chassis first...decisions.
    Spec is currently:
    MTM Map (Kim Collins) Anyone had this done?
    Miltek Cat Back
    DV I am not sure about, I need to check but I believe its a 007p
    I was thinking front and rear ARBs, Green panel filter, and KW coilovers?
    Max
  2. Speedy Steve
    Speedy Steve Active Member
    1,258
    Disc's and pads then airfilter, then arbs and coilovers oh and dont forget adjustable rear camber bars
  3. mk1chopper
    mk1chopper Missing the S3
    1,092
    Brakes if your not already running upgrade disc's and pads upfront. Unsure on coilovers, I'd go with an uprated damper and lowering spring, unless you intend to slam it or change your suspension settings regularly. Adjustable tie bars arnt always needed, there are alternative options being ecentric bushes but adjustable tie bars will give you complete adjustment to your setup. On the power front the next mods would be front mount intercooler and downpipe with a remap to suit (stage 2)
  4. finesse
    finesse Active Member
    2,805
    Brembo GT
    Upgrade suspension
  5. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    well if your planning bolt on mods (performance wise) do these before a remap simples
  6. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,132
    1,971
