Recommend me somewhere to get number plates made up..
70AC Aug 24, 2010
  1. 70AC
    70AC 35Hz
    My rear is looking a bit tusty :blink:
    Where do you get your plates made?
    I'm after a good quality plate, simple 3D or Carbon road legal font, black border. No badges or slogan.
    Ideally I'd like an option to buy just the rear plate.
    Good value price also appreciated.
    Many thanks
  2. SneakaFreaka83
    SneakaFreaka83 ASN is hazardous 2 your wallet
    348
  3. AudiA3BE
    AudiA3BE A3 Black Edition (Black)
    I didnt think the german plates were legal in the UK??
  4. jungleman
    jungleman Well-Known Member
    2,035
    42
    They arnt
    But you can still get road legal pressed metal plates from dubmeister
  5. jungleman
    2,035
    42
    They arnt
  6. AudiA3BE
    Ahh ok, (Finds V5) :) they look awsome but always been hesitant to buy some due to my doubt on the legality of them.
    Cheers!
  7. lgooch
    lgooch Well-Known Member VCDS Map User
    1,156
    154
    try craigs plates on the internet.
    Basically design your own !
    Saves you having to go down to halfrauds with your V5
  8. jungleman
    2,035
    42
    They are fine, got all the correct marks, taken mine through and MOT and had endless coppers sat behind me able to have a good look and never had an issue
    Should get a set haha
  9. 70AC
    70AC 35Hz
    Thanks for the replies.
    I'm not sending my documents off - scan & email or offshore based only.
    There are loads up on eBay. Can anyone recommend a reliable seller? Cheers
  10. lgooch
    1,156
    154
    Sorry mate. Never used ebay. Only ever ordered from www.craigsplates.com
    Never had any problems with them, but dont know if you can just order the front or back. TBH I woudl just buy the pair ! If you ever come to sell your caer the first thing I look for is if the plates match, if they dont it usually a sure indication that a plate has been replaced and possibly due to an accident.
  11. SneakaFreaka83
    348
    Dude.. click on that link i sent then it goes straight through to craigs plates.... thats where I got mine from and had no problems with them whatsoever....it does get a bit confusing I agree as it asks if you want 2 front or 2 rear.. just do what I did and sen them a note stating what excatly you want... hope it helps..
  12. b19ctr
    b19ctr The King of Cannock
    653
    59
  13. Pii
    Pii Member
    748
    I think dubmeister sounds good and craig are also quite reputable.
    I ordered my set from Demonplates and didn't need any V5 docs to go off or anything.
  14. lgooch
    1,156
    154
    yeah if you order the 100% legal plates off them you have to send your V5 off. If you order shown plates, but just type in the legal plate number you dont have to send them anything.
    the only difference will be it doesnt have the Bs number on the bottom of the plate. Buts lets face it what copper is gonna pull you for that and I cant see an MOT inspector knocking you for it
  15. Pii
    Pii Member
    748
    I have the BS code on mine also as I ordered the legal plates from the site.
    So far as I am aware I should have no problems with MOT as mine are completely normal.
  16. SneakaFreaka83
    348
    ... can I just ask what reason they would fail you on the MOT for having pressed plates without the BS code??????.. I have had pressed plates for over 4 years and never had a issue with them... and mine are actually show plates... cheers
  17. lgooch
    1,156
    154
    Point I am makign is that 100% legal plates have to have the Bs code on them. In order to obtain them from craigs plate and most online retailers you have to send them your V5 as proof of ownership.
    If you order show plates which can look 100% legal with the correct fonts and spacing you dont have to send or show a V5. However it will not display the Bs number on the plate and technically they are illegal and shoudl not pass an MOT. However the lettering is so small most coppers wont pick up on it and MOT testers often over look it especially if the plate font, lettering and spacing is legal.
    Pressed plates are illegal as they do not reflect !
    If you order the german style ones then even the font is illegal.
    I have an illegal plate on the Golf at the moment and only been pulled once in 5 years. I have S80 OCH and it reads S 80OCH. It is the wifes name
    Hope that this helps
  18. SneakaFreaka83
    348
    cheers for that fella.... yeh I am the same been pulled a while back as ive pressed mine together so its G9MBO no space but no that I have said that i bet i drive home from work and get pulled haha.. thanks again fella....
  19. Lee_R
    Lee_R Active Member
    2,499
    12
    i've always used www.fancyplates.com
    No V5 needed as based in Ireland so no legality issues
