recirc valve
jay22s3 Mar 12, 2013
  1. jay22s3
    jay22s3 2nd gear sorts em out
    210
    does anybody know where i can buy an uprated recirc valve from for a 1999 s3 ?
  2. CMcKenzie
    CMcKenzie It's supposed to do that..
    318
    127
    43
  3. <tuffty/>
    21,781
    4,165
    Define uprated... they are not really uprated, they have until recently been a down grade lol...
    Forge 007p is a serviceable valve and will outlast the OE ones in general but OE ones are as good at doing the job...
  4. S3 Es
    S3 Es Member
    Has this changed now then are the DV's forge churn out better quality/more reliable now or still prone to leaking and failing as many have commented on here?
  5. <tuffty/>
    21,781
    4,165
  6. badger5
    9,575
    2,038
    Forge valves being sold now are fine..
  7. jezzy
    jezzy Member
    768
    OEM valves being sold now are fine as they have always been and considerably cheaper;)
  8. Rice
    Rice Active Member
    247
    37
    I hear the 710N used in the rs6 is the best oem valve to go for. Theyre only £30 odd too. Thats what im going to get i think.
  9. Mikemm
    Mikemm New Member
    Hi I'm new to the thread. I bought a 1998 Audi A3 1.8t. It came with a baileys atmospheric dump valve. I want to get rid of this dv and fit a recirc but I'm not sure on how to do this as the previous seems to have welded the dv on the boost pipe which I didn't think was the correct way of doing this. If you could advise me on fitting that would be much appreciated. Also will I need to get a new boost pipe or can I blank off were the current dv is?
  10. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    i run the oe one and it holds boost better i found but thats me
  11. S3 Es
    S3 Es Member
    I wonder if anyone has any experience of this, and would it need mapping to work right or would it work fine on an unmapped engine?
    Im also wondering other than sound maybe and the fact that a forge could be modified with different springs for different boost levels etc what the hell is the difference, I'm running a bog standard 225 BAM with a cone filter but want to start getting it tuned up what way do I go?
  12. <tuffty/>
    21,781
    4,165
    Dump valves don't need mapping or tuning.... the Forge spring thing is a myth... you only realistically need a green spring
  13. S3 Es
    S3 Es Member
    Nice one tuffty, might have to give the 710n a go.
