Recently moved to Halifax
MarkTweedley Jan 22, 2011
  1. MarkTweedley
    MarkTweedley Member
    144
    Hello!
    Recently moved to Shibden.Halifax ad just wondering if anyone can suggest some decent garages/specialists for if/when I need one?
    I will be replacing the DMF and clutch in the next month ish and would be great to know a reasonably priced garage that will do a good job.
    Also I'll be needing 4 18" tyres in the next week or two so any info on a good place for tyres and do you think 225 40 18 will be about right?
    Thanks peeps.
  2. roman3000
    roman3000 Member
    316
    I dont know any garages in Halifax but changing clutch and DMF should cost around £200/£250 labour, don't get ripped off :D
  3. NHN
    29,300
    1,702
    Thats the best place to be for parts these days isnt it :p albeit illegal ones
  4. sub39h
    sub39h Active Member
    2,502
  5. MarkTweedley
    MarkTweedley Member
    144
    Thanks guys.
    Will a 215 40 18 tyre be ok or will it look daft? Think the alloys are either 7" or 7.5" wide. Thanks
  6. sub39h
    2,502
    if they're OEM they should be 7.5J, and then 225/40R18 are probably the best. if you go down to 215 then the rolling radius changes and your speedo reading will be out
    this can be fixed with VAG-COM but just something to be aware of
  7. mike foster
    3,967
    This place does my work and they are good and competitive. Timing belt, water pump etc plus longlife service £530 all in (IVC quoted £605). Intercooler pressure pipe replaced £68 all in. Only genuine VAG parts used.
    Just off Roundhay Road in Leeds
    www.volksworks.net
  8. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,196
    383
    I would recommend FAR Servicing at Wyke, genuine decent bloke. Other than that Chris Umpleby off Thornton Road Bradford is also one to think about. I wouldn't go to the dealers around here unless you have to as they are all owned by the same group.
  9. a9503128
    a9503128 Guest
    Oh Dear, I grew up in Halifax and made for London as soon as I realised what a toilet it is!
    Anyway you live in the better area if Town with a dry ski slope behind you and a giant park infront of you...... For your Tryes go to Pellon Tyres they are a blackcircles.com fitting centre so you can get internet prices fitted locally.
    Re the garage volksworks in Leeds are OK and Hares (or Hare) in Illingworth are ok, id take it as a pintch of salt though iv not used them in years.
    Ps "the works" in Sowerby Bridge is a real ale pub in an old wood works and worth a shot.
    PPs if you need body work my nephew has a bodyshop I can point you in the direction of.
    PPPs Partco Autoparts Ltd Halifax, Unit 1 Queens Road Industrial Estate for your parts.
    Alex
    All the best
    Alex
  10. MarkTweedley
    MarkTweedley Member
    144
    Thaks everyone and cheers Alex for the local info. Yeah I've seen the ski slope. I'm living here for a few months or so with my bro. I may stay up this way or move back to Lincoln at some point. My bro uses Pellon tyres actually so that may be worth a shot.
    Thanks again.
    Mark
