Recall on the S3 - dealer just told me
Irish Jul 31, 2007
  1. marshalld
    marshalld aka dazzler Audi S3
    145
    30
  2. shamsher
    shamsher Member
    41
    Looks even better in the dark with the needles glowing!
  3. klauster
    klauster Well-Known Member
    1,188
    112
    ah great now I see... thanks :)
    I still prefer no ECU update and the extra 50 horses :p
  4. JamS3
    JamS3 Active Member
    2,258
    20
    Any other format to windows media?
    Mine does not work and has not done for ages!
  5. marshalld
    145
    30
    Just for you Jam, now on youtube:
    Youtube needle sweep linky
  6. daviscup
    daviscup Member
    134
    As seen on the Astra and Corsa VXR. Still think its cool? :)
  7. JohnS3
    JohnS3 Active Member
    3,032
    Jamie, Can you ask your tech mate at Audi if this feature can be enabled on the older cars? Cheers
    Regards, John.
  8. JohnS3
    3,032
    A chap on tyresmoke says the needle sweep can be turned on and off from the DIS.
  9. klauster
    1,188
    112
    oooooo how ? :lazy:
  10. JohnS3
    3,032
    He thinks it's in the area where you can turn off the lap timers etc it's listed under dials. He's going to check tonight and post his findings. I can't check on mine as it's currently about 1000 miles away from where I am at present. Doh..
  11. klauster
    1,188
    112
    i can look, where should i look? go into the lap timers?
  12. JohnS3
    3,032
    It's the settings part where you can choose if you want them to be displayed or not. This may only be on MY08 cars or possibly the ECU update cars. I can look for it on mine when I'm back on Thursday.
    Regards, John.
  13. klauster
    1,188
    112
    well i just went through all the menus and couldnt see any reference to the dials at all, so its poss its only on the newer S3's :slap:
  14. TheWusMan
    TheWusMan Member
    60
    Lovely ... a MY08 feature that probably requires a full ECU reflash.
    I'm going to stare very very hard at the dials on mine and see if my jedi mind trick will get them to turn like those in the youtube clip.
    I'm starting to think there is an ECU code revision just for the S3 mmm...
    Perhaps good for some other fixes - seeing that this is a relatively new spec engine for VAG ..... kind of like a BIOS update from S3 v1.0 to S3 v2.0 heheheh.:rockwoot:
  15. klauster
    1,188
    112
    all well and good, but I dont want to lose my remap, surely the dials thing could be switched on using VAG.com? (if thats the right spelling)
  16. JohnS3
    3,032
    These are not the dials you are looking for, move along please....
  17. TheWusMan
    TheWusMan Member
    60
    LoL:)
    Could've sworn they moved a bit this arvie when I tried it ...
  18. JohnS3
    3,032
    From Sparky over on tsn -
    DIS Menu > Set > Indications > Dials (tick/untick)
    It's been confirmed that this option is not shown on MY07 cars. I'll have a go at this on Thursday, will let you know what happens unless someone beats me to it.
    Regards, John.
  19. markwiggy
    markwiggy Third Gear
    1,132
    94
    Just checked the menus on mine, nothing. So will just have to order a new car.
    Mark
  20. klauster
    1,188
    112
    hehe Mark, that is a solution! :w00t:
  21. klauster
    1,188
    112
    Keep us posted please....
    Will Audi be able to add this functionality to our S3's or is it a new car as Mark suggests :laugh:
  22. markwiggy
    1,132
    94
    Are we really that bothered !!! You will only see it when you start the car and nobody else will see it unless you point it out to them.
    Also the software Etc to operate this may add extra weight ,therefore slower car.
    Mark
  23. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Well you could always leave you Vag-Com plugged into the car and run the cluster output tests every time you start the car - LOL :)
    That way you'd get a full cluster sweep though you'd probably have to next through each dial.
    Paul
  24. klauster
    1,188
    112
    balls to it, I dont even know why im bothered, getting rid of it early next year anyway...
  25. JamS3
    JamS3 Active Member
    2,258
    20
    Will do mate, standby!
  26. markwiggy
    1,132
    94
    It aint going to change your life matey !!!
    Mark
  27. Irish
    Irish Member
    190
    Mine doesn't do this either !!
    I think the S3s with the dodgy electrics are the ones that do it. :)
  28. S3Didge
    S3Didge Member
    91
    Mine neither - can't say i'm fussed are you guys sure it's not a fault? ;)
  29. JamS3
    JamS3 Active Member
    2,258
    20
    Dont think we can add it to ours my mate seemed not to think so but is still checking. Interestingly though the local delaer said no ecu reflash was needed on mine?
    It was registered mid Jan 07 but pdi took place in Nov 06 as far as I can remember.
  30. JohnS3
    3,032
    I'm back home tomorrow so I'll see if I can find anything on the DIS.
  31. markwiggy
    1,132
    94
    Mine was also delivered Mid Jan build week 1 and no reflash required.Must only be on the early 06 cars then.
    Mark
  32. JamS3
    JamS3 Active Member
    2,258
    20
    Its strange though that mine was in the country in Nov 06 as it had its pdi then but does not need a reflash?
    I would have thought this would make it a early 06 car for a S3 anyway as they only became available from Sep 06?
  33. markwiggy
    1,132
    94
  34. JamS3
    JamS3 Active Member
    2,258
    20
    It was a cancelled order so sat in the showroom for a very short while until I bought it.
  35. markwiggy
    1,132
    94
    I see !! That explains things.
    Mark
  36. JohnS3
    3,032
    Well I've had a good look around in the DIS and can't find any mention of dials under the set menu. It could be a vagcom job or just not possible.
    Regards, John.
  37. JamS3
    JamS3 Active Member
    2,258
    20
    It may be possible on vagcom John, something my mate is checking when he has time. On the old S3 you could move all the instrumentation via vag com to see if the needles were working correctly.
    Cant see Audi taking time and money to develop a total new feature on the 08 cars unless it was very easy ie vagcom to change!
  38. JohnS3
    3,032
    I know someone who is getting an S3 next month. If he'll let my check the coding for some of his modules with vagcom I can compare them with mine to see if an unused bit has now been enabled.
    Regards, John.
  39. JohnS3
    3,032
    Hi Jamie,
    I looked at the instrumentation tests with vagcom and you can still sweep both the speedo and rpm needles, though it's not as fast as the video posted by marshalld.
    Regards, John
  40. thebears
    thebears Member
    90
    mine doesnt do it either an no mention of Dials in the DIS!
