Rebuilt gearbox with better ratios! Anybody??
Discussion in 'Tuning' started by ant123456, Nov 2, 2007.
  1. ant123456
    ant123456 New Member
    Oct 28, 2007
    27
    Has anybody on here got a S3 running 350bhp + that has rebuilt there gearbox to give better gear changes, espically 1st,2nd and 3rd?
    There must be somebody out there on this forum that has done this?:jump:
  2. Advert Guest Advertisement
  3. Backdraft Motorsport
    Backdraft Motorsport 1.8T & 2.0TFSi Specialists
    Site Sponsor
    Sep 19, 2007
    212
    73
    We are able to offer a service to change the ratios in the gearbox for you. Is this what you mean, or dont you like the way the your gearbox changes gear?
    Regards,
    Mark
    Backdraft Motorsport.
  4. ant123456
    Oct 28, 2007
    27
    Both :) Run out of gears to quickly in 1st, 2nd and 3rd. 4th is onwards is almost spot on. Only thing i am worried about is introducing lag if the gears are lengthened. Need to get this sorted so any advice, prices that you offer would be great.
  5. Backdraft Motorsport
    Site Sponsor
    Sep 19, 2007
    212
    73
    Hi,
    Our race car is running a 1st gear half way between standard 1st and 2nd. 6th gear is half way between standard 5th and 6th. The rest of the ratios are spaced out evenly. This gives us a tall 1st gear for starts and use of all 6 gears up to around 140MPH, which is as fast as we go on the long straight at Snetterton.
    I imagine that you will actually want to make 1st taller all the way up to 6th which you will want taller also.
    Please let me know what you want exactly, if you will supply the gearbox in or out and any other items you need?
    Regards
    Mark
    backdraft Motorsport
  6. jo3y
    jo3y New Member
    Nov 22, 2007
    23
    Hello mate. I've actually purchased the S3 from Ant now. Can you please give me an Approximate cost for the above? I would be interested in lengthening all the gears all the way upto 6th, as Ant has said the first three are probably too short the rest are fine but sixth is probably a little to short for motorways. Can you also provide some recommended ratios and the speeds attained in each gear for a car with this amount of power. Currently it's on full boost from 4,200 upwards and motorway cruising is probably suffering from it. Cheers.
