Reasons for a slightly lumpy idle?
iR8V10 Jul 2, 2012
  1. iR8V10
    iR8V10 Noob
    73
    20
    Only notice this when the car is idling, with the a/c on or off. The revs dip by a hundred or so every couple of seconds.
    I had the MAF replaced as it was showing intermittent fault and there is no obvious misfire showing on vancom either.
    Any ideas?
  2. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,498
    214
    Vacuum leak possible, have a smoke test done at garage. Nearly all my hoses are silicone upgraded now.
  3. iR8V10
    iR8V10 Noob
    73
    20
    Will get it tested, thanks!
  4. s3mad_dude
    s3mad_dude Noggies ruuuule!
    622
    80
    Yeah mine is a bit lumpy too - maybe it's a noggy thing! Sometimes it's fine, other days just seems a little lumpy. I'll get it checked out when it's serviced. I don't think it's anything to "worry" about, but it certainly is annoying.
  5. iR8V10
    iR8V10 Noob
    73
    20
    It's just one of those niggles... Like my perished radio antenna base. Going to get that sorted too!
  6. s33nyboy12
    1,498
    214
    Annoying........ Try having an over rev each time you change gear and 2 specialists ant solve it for love or money! That's annoying lol
    iR8V10 likes this.
  7. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    That could be your clutch sensor btw
  8. s3mad_dude
    622
    80
    Haha I had a perished radio base too (first job I did after replacing the S3 steering wheel badge the day I picked it up!). Phoned Audi and they said they don't provide the part anymore but sold me the A6 base instead which is identical. You can get it on it's own (so you don't need to fork out for the mast too). It was about £10-15 iirc.
  9. iR8V10
    iR8V10 Noob
    73
    20
    Good to know, thanks!
  10. s33nyboy12
    1,498
    214
    Already replaced with new one, and tried scrappy one and it revs slightly up on let off accelerator not just clutch change......
  11. Paradox1
    1,833
    88
    Do you have a splitter valve or an atmospheric one?also do you have a catch tank? If so make sure the drain screw is tight
  12. s33nyboy12
    1,498
    214
    I have forge 007 mate and no catch can, standard pcv system apart from bits of silicone and new hockey puck. Are we onto something boss? Hope you can help me lol
