rear wipers come on when i engage reverse gear
Alva78 Sep 11, 2013
  1. Alva78
    Alva78 Member
    110
    9
    Has any one had his happen?.i have a a3 3 door black edition 2009 tdi.it.The rear wiper on turns once has had a service recently but cannot remember if happened after the service .I not too concerned but worried if it is the start of other problems.Can anyone shed any light on this.The rear wiper only turns once or every time i engage reverse gear.
  2. NHN
    29,295
    1,701
    Normal, its coded to do this & its merely a safety feature for making sure you have a clear view as such.
  3. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Believe it is a feature (not a problem). When you select reverse gear, the wiper operates just to give you a nice clear view of what you will run into. Great idea by Audi. Don't mind it a bit! Cheers.
    phil76 likes this.
  4. DomH
    DomH Active Member Audi S1
    199
    52
    Totally normal, even my 9N3 Polo did it!
  5. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,149
    376
    :laugh:
  6. Alva78
    Alva78 Member
    110
    9
    Thanks to all ,it did not do it before so the Audi service must have cleared the coding issue,mind you £147 an hour i might have to go to an independant from now on...
  7. Jack_tdi
    Jack_tdi Member
    287
    12
    Isn't just audi....
    My W reg Rover 25 did this..... (My first car btw don't hate!! We have all been young once )
  8. turbonutz
    turbonutz Active Member
    421
    61
    dont think my car does this, never noticed ha
  9. S3_Jacko
    S3_Jacko Well-Known Member
    1,734
    574
    neither does mine mate... we must have the pre-feature model ha
  10. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Gold Supporter Team Silver Audi A3 TDi
    484
    164
    43
    With mine it will only single sweep in reverse gear if I've turned the front wipers on first so as I have to reverse off my drive way it's always worked that way,no wipes on no single sweep
  11. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    Mine does this - I am going to keep quiet about the previous cars I had that did it too :)
  12. smurfworth
    smurfworth Well-Known Member Audi S3
    1,906
    528
    Most annoying feature in the world, makes you have to clean the car because you have a clean patch while the rest of the window is dirty
    Boon likes this.
  13. Boon
    Boon Active Member
    441
    59
    Only sweeps when the front wipers are engaged if its coded to work
    But I turned mine off for the above reason! Never use the rear wiper, G1 keeps it clear :p
  14. LEE69
    2,149
    376
  15. LEE69
    2,149
    376
    Tried to alter mine and its not there to activate
  16. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    In VCDS, is it possible to disable this feature but not disable the rear wiper all together?
  17. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Mines a 2005 and does this, I hate it and am going to get it coded out.. drives me nuts, masive wiper patch over my rear screen...
  18. AudiMafia
    AudiMafia Member
    403
    13
    The reason is because you have pushed forward the wiper leveller this activates the rear wiper every time u revers
  19. Boydie
    Boydie Boycie VCDS Map User
    3,246
    352
    Remove rear wiper - problem solved.
    pwilliamson1991 likes this.
  20. LEE69
    2,149
    376
    I push my stalk forward and it sweeps the screen then a delay and then sweeps again.
  21. grantDUBshaw
    grantDUBshaw Active Member
    240
    62
    I have auto headlights and wipers.. Mine only does it when auto wipers are turned on (wiper stick is up first click)
  22. LEE69
    2,149
    376
    Me too, shall it when at the car next
  23. ChrisP1303
    ChrisP1303 Active Member
    195
    Mine does this on auto wipers. Have to say doesn't bother me that much.
    Dirty window bothers me, not being able to see anything would be more irritating.
  24. phil76
    phil76 Active Member
    572
    40
    So this feature then clicks in your O.C.D feature ? cant they both be coded out ?
  25. PaulRS3
    PaulRS3 Well-Known Member
    1,208
    141
    I have a MY11 car and can turn it on/off on the DIS.
