rear wiper stuck
Haris Jul 11, 2004
  1. Haris
    Haris Member
    58
    Hey guys,
    My rear wiper is stuck as you can see on this pic:
    http://www.3rror.com/3rror/a3/AUDI%20A3%20-%202.jpg
    is it possible to fix this easy? anyone had it before? can i just pull it back below...since it's really stuck im affraid to break it...is there an easy way to remove it so i can see whats wrong?
  2. recomdos
    recomdos Active Member
    1,000
    hey harris
    I noticed this in ur pics the other day!
    [ QUOTE ]
    [/ QUOTE ]
    to be safe I'd say, do not even think of it!!!! it'll be attached to a little motor and ya don't wanna break it under forced stress. also the wiper is attached through the glass of the back window, so if things really go wrong ya don't wanna **** that up.
    does the wiper not work at all? if not - could it just be a blown fuse? (anyone?)
    if the wiper does still work, what you could do is losen it (a 12mm nut if I remember) and lift it off, then replace it to the desired point, and tighten it back up. problem here though: if the motor is stuck at a certain point, then when u switch it on, it will only rotate so far (as the motor will think it's at the end of it's cycle)
    I rarely use my wiper, but recently fitted a new style wiper - looks much tidier! you could do the same! quite simple and I even made a nice little tutorial on how to do it - clicky link!
    top tip, should you decide to remove the wiper - first just losen the nut - don't remove it, then pull the wiper off gently, as it kinda bonds into the metal a bit (u'll see what a mean - it's like a tooth impression) so it's tough to unsettle, therefore if you applied force without the nut tehre to stop it, it would fly off and possibly poke ya eye out!
    good luck with it! I'm hoping it's just a fuse or something!
    Rob /ubbthreads/images/graemlins/laugh.gif
  3. HTC
    HTC Active Member
    3,428
    9
    The rear trim inside the boot is very easy to remove. Undo the screws for the inside handle and then carfully unclip the plastic panel.
    I would then unplug the electrical connector and get a multimeter or test light on it.
    Switch the ignition on and operate the wiper. If you get a reading then the eletrical side is okay and the motor may have died.
    If you get no feed then the fuse may have popped due to excessive load.
    You can also remove the motor and hot wire it to see if it operates, if it does then it may be a bad linkage.
    Just work through methodically trying to eliminate one thing at a time.
    If you can't live with the wiper in this position then you should be able to undo the linkage, move the wiper to where it usually lives and reattach, so it doesn't look silly.
    But don't try to move it as it is otherwise you will break it.
    Hope that helps a bit.
  4. HTC
    HTC Active Member
    3,428
    9
    hee-hee, recomdos beat me to it :)
    I must be a slow typer!
  5. recomdos
    1,000
    [ QUOTE ]
    [/ QUOTE ]
    well maybe I'm a lil quicker there, but you've provided a different approach! so there's a few possibilities there matey - good teamwork! (high five!) lol /ubbthreads/images/graemlins/beerchug.gif
    Rob /ubbthreads/images/graemlins/grin.gif
  6. HTC
    HTC Active Member
    3,428
    9
  7. recomdos
    1,000
    lol - yup! /ubbthreads/images/graemlins/laugh_roll.gif
  8. Haris
    Haris Member
    58
    LOL ok thanks guys /ubbthreads/images/graemlins/smile.gif
    Ill go see what i can do...since its not moving at all..:S
  9. I have the same problem but a mate of mine who works for VW syays it can be a common problem and it is easily solved by replacing the dodgy motor. Thats what i am about to do to mine.<font color="orange"> </font>
  10. Haris
    Haris Member
    58
    what will the price of that be?
  11. benk
    benk Member
    469
    Mine always jams when I first use it after a break, getting stuck 3 or 4 times during the sweep there+back, but after that it seems to work ok. I guess it'll die good and proper soon.
