Rear wiper stops off the window
Dan_Sykes Jul 26, 2012
  1. Dan_Sykes
    Dan_Sykes New Member
    23
    Hi all, my rear wiper stops just off the window and has started to mark the paintwork. Is it easy to adjust it or is it a pig to do? Do I need a puller to do the job?
    Thanks in advance
  2. fangio
    fangio Well-Known Member
    1,523
    184
    I think if you slacken the nut a few turns, lift the wiper arm to the vertical position then waggle it off the splines, you should be able to reposition it.
    Unless it's just worn out......
  3. hades-
    9,482
    646
    take it off and re seat it
    they come off easy with no puller needed
  4. t0ph0id
    t0ph0id Member
    54
    Not necessarily, depends how old your car is. I just had to have mine cut off.
  5. hades-
    9,482
    646
    iv never had a prob with rears on any model audi
    the fronts tho what a fukker
  6. audicruiser
    audicruiser Audi Heaven
    1,865
    You need a new wiper motor mate, I expect you have excess play in it due to the seals gone inside it from the washer fluid. The motors are revised now. If you take the panel off the inside of the tailgate you may even find a brown stain where it's leaking.
    You will need a puller to get the arm off though...
