Rear wiper r
damfly27 Feb 7, 2014
  1. damfly27
    damfly27 Member
    77
    25
    Hey guys,
    I have a 2006 avant and my rear wiper has stopped working :(
    The washer motor works but the wiper arms doesn't work! I've checked the fuse and that's fine...anyone have any ideas on what else it could be?
    Thanks in advance :)
  2. GGB_8PTDI140
    GGB_8PTDI140 Audi modder
    Does the rear washer work at full strength or just dribble out? The washer runs through the motor so if its leaking it may have damaged your motor. If the fuse is good the you need to check the feed at the multiplug for the motor, if theres voltage then its likely your motor if you there's no feed then you have a break in the loom, start looking in the rubber boot joining the tailgate to the body as this is your weak spot due to opening and closing for years
  3. damfly27
    damfly27 Member
    77
    25
    Washer is at full whack so I guess next step is check the power at the multi plug.
    Cheers :D
