rear wiper on b6 avant,, not working!
Leaky Lloyd Jul 13, 2010
  1. Leaky Lloyd
    Leaky Lloyd Member
    293
    hiya lads,,my rear wiper doesnt seem to be working,, checked all the fuzes and they're ok!
    just wondering if its a common fault????
    cheers,big ears!!!!!
  2. quattrojames
    14,050
    575
    Probably the washer pipe has split where it hinges and the fluid has got into the motor.
  3. Leaky Lloyd
    Leaky Lloyd Member
    293
    this a common problem then?
  4. quattrojames
    14,050
    575
    I've certainly seen it posted a few times on here yes.
  5. paul20v
    paul20v Audi fanatic
    1,113
    Ive done 4 in work ,
    i done one just the other day on a B7 on an 06 plate so they still have not sorted it
    with mine i never use the wash , i just wipe the window when its wet,
    works for me:yes: .
  6. Leaky Lloyd
    Leaky Lloyd Member
    293
    is it expensive to put right mate?
  7. paul20v
    1,113
    The last one i stripped and cleaned up , but the one before had knackered the circuit board and im sure it was over £150 to replace
    i would pull it and have a look first its easy enough todo .
  8. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    I think I might just leave my washer jet broken then as if I fix it then it might ruin my circuit board!
    Cheers mate for the idea :D
  9. Leaky Lloyd
    Leaky Lloyd Member
    293
    ok mate,thanks for the advice,, ill have a look when i get a chance, ill let you know how im getting on with it,, thanks!
  10. Watty
    Watty ..... (_!_) Sarah's A3s #1 Fan
    404
    Mine had the pipe off near the motor, so had water inside the rear panel, so just check for any wet area's. Had to strip the back panel off to get to it, then pretty straight forward from there apart from the water had wrecked the contact pins, so had to re-route/ make new.
  11. chrisash32
    chrisash32 Member
    573
    take the whole motor out and remove the washer blade! looks loads better then!
