Rear Wiper motor replaced-jet not working properly
jnielow Dec 17, 2012
  1. jnielow
    jnielow Member
    60
    Hello,
    As above says replaced the motor at weekend wiper arm works great with no stutters!, however I am only getting a slight dribble from the washer jet!.
    This is what I have checked so far
    1/Washer bottle topped right up
    2/Washer motor working as can hear it
    3/ Washer jet nozzle cleaned and free of obstruction
    4/ Sucked the washer pipe till liquid came through
    5/ no leakage from motor
    6/ no visable leakage in footwells etc
    Could my problem be at the front of vehicle ie washer bottle motor or something?
    Any advice welcome!
    Jason
  2. danger S3
    danger S3 Member
    369
    I've seen it where the joint in the pipe behind the sub in the boot leaks and all the screenwash ends up being held in a big void below the central locking pump so it doesnt show on the boot carpet or dribble out, might be that
  3. Squirrelofdoom
    Squirrelofdoom Member
    673
    23
    the pipe has 2 joins; one behind the sub as mentioned, the other in the trunking below the airbox - try both of those. If not then you might want to take apart the motor and make sure the spindle inside hasn't snapped
    S3 chj likes this.
  4. jnielow
    jnielow Member
    60
    Hi, Have read the suggestions and it has lead me to looking in the void below the central locking, how can you gain access down there? it looks like someone has placed a plastic bag around the central locking motor which would suggest that it has happened before or they are just protecting the motor. Are the pipes coloured i have seen a yellow/pink pipes? Will have another look anyway!
    cheers
    jason
  5. danger S3
    danger S3 Member
    369
    the pipes to the central locking pump are coloured, i think mine were blue and yellow. the hose for the rear washer should just be black and corrugated, it might be wrapped in cloth tape.
    to gain access to the join behind the sub you have to remove the sub, there are a few nuts dotted around that need removed and the trim that needs removed then that's it.
  6. epox
    epox Active Member
    772
    74
    hi. might sound daft, how long are you holding the wiper leaver for? mine takes quite a while to push the water through to the rear jet.
    also had to blow air through the rear wiper to fully clean the **** out.
    mark
