Rear wiper has a mind of it's own! - A4/S4 Avant
S3 Wannabe Nov 10, 2010
  1. S3 Wannabe
    S3 Wannabe Member
    197
    Hi guys and galls,
    My rear wiper appears to have developed a mind of it's own recently working whenever it likes. It will work when I need it to but never actually seems to be switched off. Is this a motor issues or is their some sort of controller for the motor which has seen better days???
    Any ideas welcome!
  2. BASS 666
    BASS 666 BMW aye right dead on..
    463
    my mums went like this it was the seal inside the motor that went allowing water to get into the motor making it go mad. i tryed to get a seal but they dont sell them so i got a new motor instead.
  3. pj123
    pj123 Member
    307
    13
    Inside the motor there is a round copper disc. I cleaned mine as it was blackened where the contacts ran. I think i might have added some switch grease/lubricant. Has worked great for the last 5 years!
  4. S3 Wannabe
    S3 Wannabe Member
    197
    cheers gents, I'll try cleaning it then. how much would new motor set me back if required???
  5. BASS 666
    463
    sorry mate cant remember.
  6. quattrojames
    14,050
    576
    Often the rear wash pipe splits where the tailgate hinges and leaks fluid into the motor causing to have a mind of its own!
  7. ashatplay
    ashatplay Just Keep Swimming!
    34
    Mine did the same, the spindle passes water through it to the sprayer, this corrodes and water then leaks into the wiper motor mech. This causes your erratic wiper problem. A friend of mine soldered a small brass pipe into the spindle and his has worked fine for the last 2 years. Unfortunately my wiper arm refuses to part itself from the spindle leaving me the only option of cutting the spindle to get it off.
    Hope this helps
  8. ashatplay
    34
    Undo the star drive bolts on the wiper motor mech and see if you have water in there.
  9. quattrojames
    14,050
    576
    Can't you cut through the wiper arm and save the spindle?
  10. snowball1969
    snowball1969 Member
    114
    wiper motor from Audi £83 weli that was what Audi Bath charged me I had to cut the arm off and Audi kindly popped the spindle out as it was corrid to badly you can invest in a wiper arm puller I did place a post on here regarding the same issue
    When I replaced the arm on spindle I put some copper grease on so if I ever have to remove it wont be so hard.
    Hope this helps
    Paul.
  11. scott b
    scott b Active Member VCDS Map User
    1,254
    mine decided to start playing up last night, theres still water coming out of the rear washer jet, but not at much force, so its of to the unit shortly to look for the problem/cause
  12. scott b
    1,254
    well like ppl have said, getting the trim of was the hardest part, once i removed the trim, the motor was leaking water!
    removed the motor/gear mechanism cover to find water in there and the grease all brown.
    so of to audi tomorrow for new motor.
  13. snowball1969
    snowball1969 Member
    114
    I brought one a few weeks ago and paid £83
  14. scott b
    1,254
    best raid the bank befor i head down then lol
  15. scott b
    1,254
    well now all sorted, makes a big difference to have a powerfull rear washer jet aswell
  16. snowball1969
    snowball1969 Member
    114
    well done ))))
