Rear wiper delete/removal
matt_hilluk Jun 18, 2011
  1. matt_hilluk
    matt_hilluk facebook.com/m9tbh
    255
    17
    mixed opinons on this i know
    but i really dislike rear wipers, they tend to make the rear dirtier if anything! and i can see fine out of the rear winder with a bit of dirt/rain on it anyway.
    Now i know on the Mk5 Golf they have Glass inserts available to fill the hole made by the wiper. Anybody else done this on an A3, are they available? I dont want a rubber bung tbh...
  2. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,228
    320
    they do for the a3 yes a good few members have them my guess is they would be similar to the mk5 ones tbh but do a search on google
  3. Daws88
    Daws88 Member
    246
  4. matt_hilluk
    255
    17
    sweeet daws cheers, you got a link to the exact one and how did you glue it in?
    also, is the wiper hard to get off?
  5. Daws88
    Daws88 Member
    246
    It comes with a specialised glue, and solvent to get the rust off from where the wiper was. Try not to use to much glue if you can help it, as its hard to get off, and mine still has a white mark that i havent tried to get off yet. Im sure the liquid solvent will get that off!
    Seen some comments on here where they have just twisted it from side to side, but mine was an absolute pain to get off...dont know if this is due to being a 2005 model but i bought a ball joint seperator cup from halfords that got it off in a second. Then took it back and got my tenner back, lovely stuff!! :happy:
  6. matt_hilluk
    255
    17
    ordered my glass insert now
    will be interesting to seeif i can get the wiper off
  7. Daws88
    Daws88 Member
    246
    Good luck. If you can't just pop to halfords for that special tool. Mine was a nightmare, but the tool took it off in flash lol!
  8. Adam.
    Adam. Meow.
    662
    34
    Done this on my golf + leon. I also popped the hose for the washer fluid off on the bottle in the engine bay. Stops the boot lid getting soaked if you hit it accidentally!
  9. Daws88
    Daws88 Member
    246
    Is there two separate hoses on the washer fluid then Adam? I will also do this.
  10. Adam.
    Adam. Meow.
    662
    34
    Yeah one for the rear and one for the front.
    Due to the way the motor works, the front will constantly flow out the bottle if disconnected but the rear wont. This is how to tell the difference between what hoes goes to what end!
  11. matt_hilluk
    255
    17
    im gonna have to try this too
    also how does this special tool work
    and are their any error codes for no rear wiper?
  12. Daws88
    Daws88 Member
    246
    Ok cheers Adam, will give that a go.
    It's a ball joint separator cup. You put the cup part under the ball joint and just wind the screw onto the part that's holding the wiper together. It's easy to do and work out.
    I've had no error codes.
    Off topic but what are your lamin x headlights like? Have you upgraded bulbs to see better? I'm wanting to get it done but don't want to have poor visibility.
  13. matt_hilluk
    255
    17
    i can barely see anything at night time, need to upgrade the bulbs at some point
  14. Daws88
    Daws88 Member
    246
    Oh ok lol. That should hopefully make the difference then..
  15. PilotAudi
    PilotAudi New Member
    2,352
    479
  16. matt_hilluk
    255
    17
    lols
  17. Fivetones
    Fivetones Member
    238
    17
    Anyone know the exact size of the glass blank needed? My A3 isn't here yet so can't measure this myself - getting prepped for it though. :)
  18. Fivetones
    Fivetones Member
    238
    17
    Hmm probably the same size as my Polo so not to worry.
  19. warrenlord
    warrenlord Member
    771
    15
    might aswell ask in here instead of making a new thread, Anyone know how to fix the pipe when its not pumping water to the rear? mines just stopped working for some reason ?
    thanks
  20. danb986
    danb986 In awe of VCDS Team Daytona
    520
    60
    Not sure if it's the same on the Audi's, but on the Golf it's usually because the pipe has popped off somewhere and the water is squirting out somewhere it shouldn't. On the Golf you could easily find it as you had a screenwash smelling stain appear in the roof lining.
  21. Fivetones
    Fivetones Member
    238
    17
    Check the nozzle. If you put too strong a wash solution in the soap gunges it all up.
  22. danb986
    520
    60
    Agree with what Fivetones says. If it gets too gunged and totally clogged then the pressure has to go somewhere when you try and squirt the rear screen and that's when you can pop a pipe off. Hopefully yours hasn't done that yet, as the joins are usually hidden in really awkward places.
    Again, I'm only going by experiences with the Golf, it may be different on the A3, but it's still worth checking as a cheap fix.
  23. warrenlord
    warrenlord Member
    771
    15
    oh no! well i only pressed it a few times so hopefully it hasnt pissed out everywhere. ok so fivstone you say check the nozzle where is this on the car? i could of over done with the the wash maybe...as i used it abit recenlty.
  24. Fivetones
    Fivetones Member
    238
    17
    I mean the washer jet itself. Try and release the pipe from the back and then see if the pump will pump it through (the pumps not gone has it?). If that works then take the washer jet/nozzle off and soak in hot water.
  25. warrenlord
    warrenlord Member
    771
    15
    ah ok i get you, no the pump musnt of gone as the front washers are working fine. so i guess take off the back plastics and pop the pipe off and dress the stalk to pump water and see if it pumps out.
    thanks for that will have a look when i get time.
  26. Fivetones
    Fivetones Member
    238
    17
    Report back and we'll have a rethink if not fixed mate.
  27. warrenlord
    warrenlord Member
    771
    15
    Fixed! thanks for the info!! i was tempted to leave off the nozzle so i can shoot water at people haha!
  28. danb986
    520
    60
    What was it, blocked nozzle?
  29. warrenlord
    warrenlord Member
    771
    15
    yeah..because when i pop off the plastic cover and the nozzle part the water shot out fine!
    its been sat in hot water for ages so will clear it out later.
    thanks for the info mate was bothered it was pissing out somewhere it shouldn't
  30. Fivetones
    Fivetones Member
    238
    17
    That's good news Warren. I always thought it would be good to have something to squirt water at people who get to close to my back bumper :)
  31. danb986
    520
    60
    I thought that was why your washers have 2 (or 3) jets per side. So you had a spare one to soak cyclists with.
    london jay likes this.
  32. slizza786
    slizza786 Active Member VCDS Map User
    394
    25
  33. y2kcurran
    y2kcurran Member
    127
    24
    I was considering this on my 3dr, loved the blanked off look on my mk4 Golf...but i'm really glad I didn't with my A3, any wet weather at all and you may as well be driving a van!!
  34. slizza786
    394
    25
    Does anyone know the size of the hole in the class when the motor is removed? 19mm 22mm or 24mm?
  35. jay1601
    jay1601 Well-Known Member
    1,311
    57
    24mm. IIRC.
    i used a 25mm grommet from halfords, haven't had any problems.
  36. slizza786
    394
    25
    Thanks buddy
  37. Cmw9
    Cmw9 Member
    252
    21
    Im confused where i need to disconnect the pipe in the engine bay. I tried to disconnect both hoses from the washer bottle (behind the front fog light) and both of them keep running? Thinking about squirting some silicone up the pipe in the boot
  38. Mindak
    Mindak Active Member
    791
    130
    43
    I'm a fan of the dewipered look but with these a3's the rear gets so dirty!
    Gotta keep it clean all the time and rain-x helps a bit!
    GGG_666 likes this.
  39. GGG_666
    GGG_666 Black it out!
    207
    62
