Rear window won't go all the way down on my Cab??
vanbling Jul 19, 2010
  1. vanbling
    vanbling New Member
    My rear window won't go all the way down on my B7 Cabriolet 2.0tfsi. Still has about 5 inches more to go.
    As it hits bottom it is as if it thinks it is actually at the bottom, or in other words it isn't snagging and the motor isn't try to repeatedly come down.
    Any idea guys?
    Adam
  2. Johnytuono
    Johnytuono Member
    131
    Hi
    If its the same as the saloon I dont think its meant to go all the way down...some safety reason I think
    HTH
    JohnyT
  3. old-man
    old-man Member
    39
    My 08 cab windows go all the way down but alas I can't help you resolve your issue.
  4. Blackie
    Blackie Active Member
    697
    67
    Perhaps its hitting a speaker cable ...Mine go all the way.
    Perhaps it may need a vag . com check
  5. HARRIM00
    HARRIM00 New Member
    9
    Mine has done exactly the same today. Does anyone have any ideas?
  6. HARRIM00
    HARRIM00 New Member
    9
    About to strip mine down unless someone can help.
  7. vanbling
    vanbling New Member
    How did you get on with the strip down Harrimo?
  8. HARRIM00
    HARRIM00 New Member
    9
    Stipped it down, nothing out of place, greased and lubed, nothing. Think it is the regulatory. Tried various resets, none worked. Big job to do the reg, glad I've got a warrantee.
  9. vanbling
    vanbling New Member
    Keep me informed on this Harrimoo
  10. vanbling
    vanbling New Member
    What resets have you tried Harrimoo, I could give that a go.
  11. vanbling
    vanbling New Member
    As an update to this thread my window has now started working as it should, how odd! All is now good.
  12. Yagy
    Yagy 007
    My driver side rear window on my 2007 a4 cabriolet is doing the same thing all of a sudden. Did anyone find a fix?
  13. o0timbo0o
    o0timbo0o Member
    58
    My 06 drivers rear window also started the same trick, won't go down the last 6 inches.
    Is there a reset procedure ?
  14. bebecheekymonkey
    bebecheekymonkey Member
    40
    Hi,
    Same thing happened to my wife's car today. Also a B7 Convertible 2.0TFSI. To fix, 1. ensure all windows are up. 2. Unplug the battery for the car. 3. Leave for at least ten minutes. 4. Re-connect battery. 5. Open and close each window fully. Hey presto....it works. The rear window opens fully. 6. Reset your car's date/time and also sync your keyfob with the car again.
    Good luck!
    Bebecheekyfamily!!!
