Rear window wiper not working
Rosario7 Dec 21, 2009
  1. Rosario7
    Rosario7 A3 2.0 Tdi Sportback
    20
    Hi everyone,
    yesterday while de-icing my car, the rear window wiper suddenly stoppped working. i've checked the fuse and its still intact, so i left it for a while in case it had frozen but still nothing. Is this a common fault?? is there anything else i can check before considering a new motor?
  2. smudge_don
    smudge_don Active Member
    2,944
    If it's not the fuse, then it must be the motor mate
  3. a_sagad
    a_sagad Member
    119
    sorry to hear that mate, a quick question, my back wiper is working, but the water doesn't seem to come out anymore once it was finished, i've top the water level up and the front wiper squirts fine, but the back one doesn't.
    Any advice/hints/tips???
  4. Rosario7
    20
    a sagad Its probably the jetta holes are clogged up, have u tried unblocking the holes witha needle? u can purchase the actually piece for next to nothing i changed mine not so long ago.
    ok, thanks for my reply smudge dog, now, does anybody know how much a new motor is??
  5. Nylon39
    Nylon39 New Member
    Hey,
    Mine did the same last week when it was really cold. It then started working again when the weather got slightly warmer. Then this morning with the car covered in snow it stopped working again. About 30min later on the way to work I tried it to see if it would start to work and it started to wipe but only got 1/3 of the way and stopped again. Not sure what it will be but just seems a bit odd that its only not working in the very cold weather.
    By the way, first time posting but been following this forum for a while and its great.
    Thanks guys.
  6. Rosario7
    20
    Thats pretty much whjat happend to mine Nylon39.
    But, i have just finished speaking to a friend who works at audi and he advised me to check the connection first and see if they are all tight and secondly he advised that the wire breaks on the near side loome on the hinge. ill check it out tonight and let u know the outcome.
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    also check if the water is dripping out of the tailgate etc. The pipes have been known to pop off due to frost. When you use the washers it just runs out the end of the pipe, often into the tailgate area.
  8. a_sagad
    a_sagad Member
    119
    Khufu - I'll have a check today when I get back home.
  9. bigpupcooper
    bigpupcooper New Member
    14
    Did you find out what the issue was? Mine has stopped working today
  10. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Usually a water leak from a split washer pipe causes corrosion in the wiper motor.
  11. bigpupcooper
    14
    The motor or jets aren't working (no noise). So I think it's either a fuse or connector with mine. I'll see tonight when I find the fuse box, where ever it is.
  12. bigpupcooper
    14
    Sorted. Fuse wasn't pushed home.....phewww
  13. paul h
    paul h New Member
    15
    Hi they have a common fault due to the washer jet running through the middle of the motor arm,they leak into the motor and this causes them to stop working,had the same problem was intermitent first off all and I thought it was wiring but when I removed the wiper motor it had rusted up inside due to the washer jet water running through the middle of the arm...hope this helps...
    bigpupcooper likes this.
  14. paul h
    paul h New Member
    15
    so looks like new motor...
  15. bigpupcooper
    14
    Thanks. Next time it happens I'll take the cover off to check.
  16. paul h
    paul h New Member
    15
    good fuse cheaper than a motor...
