Rear window washer question....
Kriminal Feb 25, 2011
  1. Kriminal
    Kriminal Member
    176
    I chucked the car in for a major service today, and all went well....well, pretty much.
    The only things that came up with probs were the brake fluid needing changing, and the rear wiper washer thing not working. The wiper works, just not the washing fluid thing.
    Would this fail on an MOT because of the washer facility not working ?
    I think personally I'd much prefer it if they just removed the whole damn wiper, and replaced it with a bung.
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    The rear washer & wiperblade are not part of an MOT. I'd unclip the cap off it & then pull of the jet. Now try the washer & see if it works as the nozzle can get blocked.
  3. mike foster
    3,967
    And if it doesn't, stop trying it because, if the pump is going and you have water in the bottle, then it's going somewhere, probably inside the boot lining !
  4. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Kriminal, there is no logic here to remove the rear wiper which is there to give you good visibility. Better to do as Khufu suggests and make the wiper functional again. Cheers mate.
  5. RU55SSO
    RU55SSO Member
    792
    24
    Probably blocked due to poor quality washer fluid that has congealed over time. As said earlier unclip the nozzle jets and clean them out with a pin
  6. Khufu
    5,704
    31
    or carpet at drivers footwell!!
  7. Kriminal
    Kriminal Member
    176
    Thanks everyone - I'll have to try the above and check it out myself. It sounds simple enough <gulp> :thumbsup:
  8. Garf
    Garf Member
    39
    Anyone know the part number for the rear jet? and the price? mine was blocked, so i tried to unblock it with a pin and the pin snapped inside it. New one is needed.
  9. RU55SSO
    RU55SSO Member
    792
    24
    I have a spare jet somewhere mate. PM me your address and if i can find it ill post you it
  10. mike foster
    3,967
    If you need it the part number is :- 8E9 955 985 spraying jet approx £6.50
  11. Garf
    Garf Member
    39
    cheers mike, and thanks Russo PM sent.
