Rear window washer not working?
Jonezy87 Dec 5, 2010
  1. Jonezy87
    Jonezy87 Member
    124
    as title, pump can be heard working, fronts work fine. Its not because its frozen!
    Thought i would ask on here if there are any common places where pipes come off or get blocked before i start looking?!
    many thanks
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,294
    372
    mine has recently stopped working as well, since its got really cold, but its not frozen either, its had ages to thaw out now
  3. Jonezy87
    Jonezy87 Member
    124
    really annoys me as im constantly looking out me back window so like it clean! and in this weather with the roads it gets filthy!
  4. KB
    KB Member
    195
    theres a connection under the bonnet, its in a black plastic trunking with cables in it on the right handside of the engine bay, prob best to take out the airbox to get at it! then once that one is fixed the one in the boot will go! its just next to the cd changer and subwoofer in the boot!
  5. Duktor
    Duktor Member
    282
    there is also the connection at the rear wiper motor mine has come of 4 times in the last cpl of months its doin my head in ,
  6. danger S3
    danger S3 Member
    374
    19
    the connection under the bonnet went on mine and so did the connection onto the motor on the boot lid
    I ended up replacing the hose from the motor round to the connection under the subwoofer with a bit of 4mm silicone hose as the end onto the motor had split and wasn't staying on at all, after all that i found it still leaked from the washer motor and that the wee brass pipe had corroded and snapped so got a wee repair kit to sort that
    its all working now though :-D (touch wood)
  7. jay1601
    jay1601 Well-Known Member
    1,344
    73
    mine doesn't work either, anyone got a pic of what pipe it looks like ?
  8. 666markyboy
    666markyboy Well-Known Member
    1,228
    55
    It always happens in the cold weather... the jet freezes up and when you flick the switch to clean the screen the pressure builds up inside the pipe because of the frozen jet and eventually the pipe bursts at the weakest point, normally in the trunking behind the airbox under the bonnet.... does anyone know if the washer jets are heated on the A3 ??? they used to be on the older Audi's but it was a common part to fail as they were on all the time with the heated mirrors.... might look into this as a mod if they are not what with this cold weather looking like it's here for a while
  9. 666markyboy
    1,228
    55
  10. Duktor
    Duktor Member
    282
    cant answer your question markyboy but ill post this link here its quite a big thread that leads to others but very usefull for anyone who needs to locate the points where the fluid pipes join , i sourced all mine except the one at the sub location and cable tied the joints up , worked fine on the one under the air box and in the trunking but the rear motor one is an absolute cnut keeps popping off no matter what i do so leads me to think its not heated as it always produces a very weak leak onto the rear window just before it stops alltogether so reckon its freezing on the outside , short of using less water and more antifreeze i dunno how to fix it so best read through this threads and make yer own mind up
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/74664-washer-fluid-leak.html
  11. a3tdi2001
    a3tdi2001 Member
    437
    Just wondering if it's possible to get to the connector under/behind the subwoofer without removing the side panel trim?
  12. sportquattro
    sportquattro Active Member
    845
    51
    Yes you can get at it without removing the subwoofer, I had to do mine recently and it's not too bad once you feel for the pipe.
  13. a3tdi2001
    a3tdi2001 Member
    437
    Cheers.
    Is it below or up behind the unit? I take it, it's just a case of pushing both ends back together?
  14. stu_b
    stu_b Member
    59
    yeah where abouts is it in relation to the speak box just had a look at it and dont fancy tearing my boot to pieces to get to it!
  15. sportquattro
    845
    51
    Mine was behind the sub box, once you've found both ends they just push together and job jobbed
  16. stu_b
    stu_b Member
    59
    i think ive found it at the 12 o clock position in relation to the sub? surely not a good idea to have washer fluid coming out there!?
  17. stu_b
    stu_b Member
    59
    fluid is bright green? and there seems to be a rather big puddle above the wheel arch! could it be the alarm battery leaking as well? doesnt have the smell of washer fluid
    stu
  18. Eric Astle
    Eric Astle New Member
    12
    Just undertaken this fix myself. Mine had come uncoupled in the trunking located in the engine bay. As a footnote for S3 owners - to remove the trunking lid to get at the coupling on the washer pipe you first have to remove the strut brace. This is simply a matter of removing 3 nuts per side on the suspension strut towers. I dried the plastic joint thoroughly and applied bonding solution to the coupling and then wrapped it up in insulation tape to prevent it coming undone again in this location. Thanks to all for the helpful information which aided me in locating the cause of my leak and non-operation of bidet (rear wash wiper)!
