Rear wheel bearing
Gunny110 Nov 22, 2013
  1. Gunny110
    Gunny110 Member
    271
    19
    How hard is it to do a rear wheel bearing? Garage wants 150! Nearly fell over!
  2. aragorn
    18,608
    871
    FWD rears are pretty easy! Its just a pair of taper bearings mounted inside the brake disk.
  3. Gunny110
    Gunny110 Member
    271
    19
    What will I need to get them out. If I order rear disks, what's the odds off getting bearings in them?
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    You won't.
    You'll need discs, pads, bearings and just in case ABS rings.
    That I got when I did mine. O and a rebuild kit for the rear calipers and new bolts.
    Personally, I don't think 150 is to bad. Its not a BSD job but it's just a pain if you don't have a press.
  5. Gunny110
    Gunny110 Member
    271
    19
    She needs a bearing, but it's 150 then the cambelt 250 and 170 for a cv boot :(
  6. Bradderz_1988
    3,988
    261
    You dont need some thing mega to put it in with using new discs, it becomes a b****** of a job pressing one out thats been in there for a good while and has a huge upright with it !!
  7. Gunny110
    Gunny110 Member
    271
    19
    Oh ok, what would do it then? Need grease obviously lol
  8. Bradderz_1988
    3,988
    261
    £170 FOR A CV BOOT !!
    do it yourself just make sure you have a strong arm (hub bolt) and the correct clamp pliers for the clips and it will cost you less than £100 with tools !!!
  9. Bradderz_1988
    3,988
    261
    vice with socket similar size to bearing or you could try something like a metal g clamp and a suitable sized spacer, you will need some circlip pliers to remove the circlip and maybe some WD or similar !!
  10. Gunny110
    Gunny110 Member
    271
    19
    That doesn't seem to bad tbh, I think I could manage it, I found bearings on eBay for 12 pound or so, is that around what is expected to pay for them?
  11. aragorn
    18,608
    871
    The rear bearings can be tapped in with a hammer and big screwdriver.
  12. Gunny110
    Gunny110 Member
    271
    19
    Aww that's easy!! Lol
  13. Bradderz_1988
    3,988
    261
    use SKF, FAG OR SNR !!
    spartacus 68 likes this.
  14. B5 BIKER
    B5 BIKER Member
    266
    As above, use decent quality bearings. Cheap ones won't last.
    i got mine prepressed in the discs with abs rotors from car-bock.de, can't recommend them highly enough
  15. I was around 300 for both rears, discs, bearings, ABS ring, pads all done. I'm a great believer in just replacing everything at the same time, less labour costs overall
  16. matt66604
    matt66604 Active Member VCDS Map User
    176
    25
    You can get the rear discs with the bearings allready installed from eurocarparts... You probably will still have to swap abs rings though...
  17. Mike_B
    Mike_B Active Member
    533
    47
    If it's like the front ones, then a press is essential. I know this, having just watched my mechanic replace one of the fronts after just over a year! To say I wasn't happy is an understatement, especially as they wouldn't do it under warranty as that was 12 months! A "German bearing" was apparently used last time - although not an Audi one at £100 or so. I go the replacement for cost, but still had a £120 bill - 1.5 hours labour overall - and it was, because I watched it. I'd certainly not try without the press. Mike.
  18. B5 BIKER
    B5 BIKER Member
    266
    On car-bock.de the full rear set pre assembled - discs,bearings,abs rotors, and pads for €129 (approx £100)
    Don't think that's too bad for German quality parts
  19. Had a look at that site, next time I need discs, that's where I'm going
    B5 BIKER likes this.
  20. matt66604
    176
    25
    Yeah I try to stay away from eurocarparts personally... They are cheap.. But you pay for what you get... And everyone knows how **** cheap bearings can be... Caliper repair kit for €8... Mint... I like this site
  21. mingilator
    mingilator New Member
    17
    the abs rings can be removed if your careful, just use a gas torch to heat it up and gently persuade it off, don't try forcing it or it will bend then its only good for the bin I pressed the bearings in one side at a time with a mechanical coil spring compressor and a windy gun just remember to put both outer races in first then the inboard bearing then the inboard bearing race before installing the inboard oil seal otherwise you will never get the inboard bearing and inner race past the oil seal
