rear wheel bearing replacement a3 18t
weelo Jun 3, 2012
  1. weelo
    weelo New Member
    14
    hi guys. new to the audi sene.. just gt a nice a3 mk1 {agu},, rear bearing has a wine lol .am nt tha familair with the a3 so any {how 2s} will be a big help!! thanks dave
  2. Y83OLK
    Y83OLK Hulk Smash!
    841
    You need a press weelo, best letting a pro do it.
  3. weelo
    weelo New Member
    14
    can you get the complete hub with bearing? would ov thought it would ov been a lot less hassel lol
  4. Y83OLK
    Y83OLK Hulk Smash!
    841
    If its a fwd you can indeed get a bearing/hub pre made combo.
    Quattro's are a bit more tricky.
    Assuming yours is a FWD model:
    Its straight forward. Remove wheel, brake calliper and carrier and disc.
    Undo the centre hub nut (30mm 12 point) replace in reverse order.
  5. weelo
    weelo New Member
    14
    yes its fwd. thanks for tha pal
  6. Dibdub1
    Dibdub1 Suck.Squeeze.Bang.Blow
    228
    Might be cheaper to get just the bearing matey and getting a friend that's either handy with the tools or is aa mechanic anyway and getting them to do it rather than forking out for a whole hub/bearing ore-pressed combo?
    Hope you get it sorted easy enough either way :)
    Dibdub1
  7. AVLO
    AVLO Active Member
    295
    52
    hi mate bit of a silly question but did you no it was a wheel bearing gone by play in the wheel or just a whine? reason for asking is just i have a bad whining which sounds like a wheel bearing but none of the wheels seem to have any play.
  8. Dibdub1
    228
    Your actual wheel won't have any play on one edge in and out as such if that makes sense, if it is a bearing you'll normally hear it start a deep grinding sound at about 30mph upwards as you gradually accelerate.
    Hope this helps mate!
  9. weelo
    weelo New Member
    14
    seems to be a whine bud.. comes n goes lol..starting to gt a bit louder now tho {ant checkd wat wheel yet}
  10. weelo
    weelo New Member
    14
    sound bud am going gsf {lincoln} in mornin..as need a dipsick tube aswell lol
