Rear Washer
dkelly Dec 26, 2007
  1. dkelly
    dkelly Member
    Hi guys
    My rear window washer has stopped working. It still wipes but doesn't wash. The reservoir is full and has been de-frosted as I have been using the front washers, but the rear just does not squirt.
    I assume itÂ’s a pipe that has become frozen and then either burst or come away from a coupling or the pump. Has anyone else experienced this? Or does anyway know how to get to the pipes and motor etc.
    Many thanks
    Damian
  2. Boydie
    Boydie Guest
    You can easily check at the wiper hinge - it jsut pops off and you can check to see if fthe sprayer has been blocked or the pipe disconnected
    to get at the motor you have to open the boot, i think there is a torque screw or two holding the plastic trim off then its a case of a bit of ignorance to get it off as its stuck on well!!
  3. dkelly
    dkelly Member
    Boydie, thanks. I have checked it all today and found the pipe was not completely connected but mainly the
    holes were clogged with salt.
    Thanks again.
    DK
  4. RGBArgee
    RGBArgee Guest
    Salt can be a problem with Bidets:o.k:
