Rear washer line, connector section in rear left arch
Squirrelofdoom Sep 17, 2012
  1. Squirrelofdoom
    Squirrelofdoom Member
    673
    23
    Hi guys,
    So I fitted a new rear wiper motor and my rear washer now works, but I get a leak coming out of the rear left arch. I know there is a connection in the water line around the sub/amp area in the rear left...I assume it popped off with pressure. Is there a guide as to how to get to that particular connection?
    Thanks guys,
    Aran
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
  3. Squirrelofdoom
    673
    23
    Thanks Alex. I think i've highlighted the connection in the red circle....is that it?...That's a bloody annoying place to get to :S
  4. Alex C
    3,261
    357
    yeah that's it, pop it back together and then tape the bugger up
    no doubt once you fixed that one the connection in the engine bay will pop apart - i ended up chasing it from the front to the rear of the car
  5. Squirrelofdoom
    673
    23
    I've already done the one in the engine bay lol, then that made the wheel arch one pop :) This was all caused by the rear motors, the spindle through which the water runs snapped and was causing a build up of pressure. have fixed that, so hopefully if I pop them all back on they should stay that way!
  6. Alex C
    3,261
    357
    ha exactly the same as me, i fixed the front and then chased it to the rear and then after all that i find that the rear wiper motor is broken like yours... car wins, i loose....its been like that for over a year now. Can't be arsed with it
  7. Squirrelofdoom
    673
    23
    I got annoyed with not being able to see out of the rear :S (my car gets dirty lol). only £20 for new rear motor....seems like lots of faff to get at that line now though
  8. Squirrelofdoom
    673
    23
    Right, managed to do it without going through all the hassle of removing all those panels. Basically, just from removing the access panel on the left, I could stick my hand in around the back of the Sub and managed to find both ends. Result!!
    Fitted back together and taped up, everything seems to work as it should now :)
    Also, while rooting around back there, found this white/black box. What is this? Seemed to be just floating around, held in with ripped up foam padding
  9. Alex C
    3,261
    357
    central locking pump
  10. Squirrelofdoom
    673
    23
    is it indeed....what a weird place to put it. Never would have guessed that in a million years!! :)
