Rear washer jet
Hotscar Jun 25, 2007
  1. Hotscar
    Hotscar Four Wheel Drifting
    562
    My rear washer is really struggling to give me any water but the fronts and lights are fine which is confusing. I've checked for blockages so the questions I am asking are; are there two pumps and is that the likely problem?
  2. S3_MCD
    S3_MCD Member
    389
    check your bootlid for a water. Pipe can easily become disconnected, altenatively the central metal shaft could have broken... if its the latter VAG parts do a replacement kit for about £20.
  3. potter
    potter Member
    41
    have a look around front ineer wheel arch to see if water comes down from there when you use the rear wash, mine came uncliped from here all fine now with new clip fitted.
  4. edward_harris
    edward_harris s3 gone now a shiney red evo 6
    1,061
    had the same problem on my old A3, it was the motor, tke the plastic cover off the boot lip 2 screws i think and clips, i replaced the motor and it was fine!
  5. Hotscar
    562
    Thanks for the replies!! I'll go through your suggestions Saturday morning...
