Rear Washer Jet on Audi A3 2010
newa3 Apr 9, 2012
  1. newa3
    newa3 New Member
    Hi,
    My Rear washer jets seems to have a block. When trying to spray water only a little bit comes out. How do I unblock my rear washer jet please? I have tried poking a pin but no joy.
    Looking on other threads the wiper should have plastic cap that pops out and the jet is under that.
    I don't have a cap its looks like the jet it moulded onto the wiper.
    anyone changed a jet before?
  2. HIGGINS
    HIGGINS Member
    528
    15
    Flick the plastic cap off. Pull the jet end off and try the rear jet and it should spray in a straight line away from your car. If it does then its the jet end, try cleaning it and try it again. If it still doesn't work get a new one from Audi, they should be less then £1 or free.
    Any more help etc PM me
  3. mike foster
    3,967
    Is it not under warranty ? Pop it into a dealer and I'm sure they will help.
  4. NHN
    29,343
    1,719
    As above, but if its the black dual jet plastic part, get a needle & clear the nozzles with some working back/forth, job done.
  5. c_w
    c_w Well-Known Member
    1,163
    87
    Is there not an issue with the rear washer leaking inside the boot? I will try flicking the end off mine to ascertain if it's a blocked jet as mine hasn't worked for ages now (57 Sportback) but fear it's leaking inside the car so never touch it!
  6. mike foster
    3,967
    Yes there is an issue and possibly will be on yours but I wouldn't expect a 2010 model to have the problem yet. If it has then it's definitely back under warranty !!
    My 2006 SB had to have a new rear wiper and it took me ages to re-tube the washer without the silly Audi connectors which pop-off in freezing conditions. The one going to the wiper motor is quite easy but the one in the rear quarter panel above the convenience module is a bugger !
    Also needed to remove, dry out and re-lubricate the boot lock to stop the alarm going off !
  7. newa3
    newa3 New Member
    i have the black dual jet plastic part. I take it there is no way of getting the jet out of the wiper?
  8. mike foster
    3,967
    Correct - the washer feed pipe is built into the wiper spindle and can't be removed.
  9. newa3
    newa3 New Member
    audi garage job then.
  10. newa3
    newa3 New Member
    Right just had the back of the rear boot lid off and there is no leak or loose pipe.
    Took the pipe out of the motor and no water came out just a few drips. Have checked all around the car and have no damp patches or puddles on the drive.
    What could be wrong here? a blocked pipe somewhere?
    car has recently been serviced and valeted inside. Could they have disconnected something during service?
  11. mike foster
    3,967
    Assuming you had it serviced by Audi then I seriously suggest you take it back to them. Tell them it worked ok before the service.
  12. newa3
    newa3 New Member
    nope wasn't Audi was a local garage. Will take it back there and if they can't fix it, will need to take it to Audi garage. Its still under warranty.
    Just that nearest audi dealer is 30mins drive and would rather fix it myself if simple fix.
  13. audicruiser
    audicruiser Audi Heaven
    1,865
    I agree, get it back to Audi!! When my car had warranty I wouldn't of even started to look at something like this!
  14. mike foster
    3,967
    You may have voided the warranty unless your garage was a VAG specialist independent.
    If you have removed the plastic washer pipe from the rear motor and water does not gush from the pipe when the washer is operated then, believe me, it is not likely to be a simple fix ! I assume you can hear the motor operating normally and you have water in the system !!!!!!!!!??
  15. Ghost
    Ghost Booooooo!
    2,176
    1,878
    and what work they do will be coved for a year, even if your warranty runs out before.
  16. newa3
    newa3 New Member
    Voided the warranty because car wasn't serviced at a VAG?
    I can hear the motor operating but no leaks so wonder were the water is going?
    Will ring local Audi garage tomorrow.
  17. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    Hi - sounds very much like mine (although mine is 05) it does look as if the whole thing is one piece (jets and wiper unit) but if you grip the casing around the spindle area, it should pop off to reveal the actual spindle. The nozzle is a small piece of plastic with two jets that is a snap fit into the end of the spindle. You may find the water is filling up the inside of the motor (mine was) - in your case that's a new motor under warranty.
  18. newa3
    newa3 New Member
    water not even getting to the motor. no leaks either.
    booked in audi garage next week
  19. mike foster
    3,967
    Nice one - sounds like the washer bottle outlet might be blocked !
  20. mmalh0151
    mmalh0151 Member
    170
    Sorry to bring up an old thread but can somebody please also look at this thread I have made and see if you can help? I am having the same issue!!!
    http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/179259-boot-leak.html
    Am I going to have to strip the whole car down to find this leak!! Its driving me mad!! Car is under another warranty (Not Audi) so do not really want to spend masses of money on it...Nor do I want to replace the rear washer jet incase it blocks again and it leaks the boot out!
  21. The Challinor
    The Challinor Well-Known Member Audi S3
    4,322
    1,101
    I found that the actual rear washer jet motor was leaking so just ordered one off eBay, and a new nozzle as I broke mine trying to clear out the junk that was trapped in it.
  22. Bedders
    Bedders Member
    104
    As others have said the most common problem is a blocked rear jet! Problem with pump is bad luck but at least you've got to bottom of it!
    To repair my blocked rear jet:-
    1. I flicked off the rear black cover
    2. Pulled the right angled jet off the wiper spline to reveal the washer supply pipe. Switch on the ignition & squirt the washer. If water comes gushing out of the supply pipe it's the jet that's blocked & the pump is fine.
    3.Blew the jet clean with a compressed air line gun & refitted. All works fine, but had just readjust the rear jets for aim with a pin
  23. mmalh0151
    mmalh0151 Member
    170
    Mine is really annoying me now....it is leaking all the time and my boot is wet!!!
    Options are to strip it myself or put it into warranty!!
  24. The Challinor
    4,322
    1,101
    Mine comes gushing out of the pipe but then the pump begins to leak all into the boot, so presuming its the pump. Should be here tomorrow.
  25. mmalh0151
    mmalh0151 Member
    170
    But I have no leak from the actual boot door lining thigie?! Its dry and when I open the boot no water comes out of it
