Rear washer jet is weak
danotto Dec 11, 2007
  1. danotto
    danotto VAG HUNTER
    1,090
    Just a quick one, when i use my rear washer jet it dribbles out and hardly reaches the screen has anyone had this before ?
    Ive checked that the jet isnt blocked and there is plenty of water,could this be a kinked tube ?
  2. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    I had the exact same problem. Check out this thread by HTC. The cost of the repair kit was £21 ish from VAG Parts and was a doddle to fit.
  3. Aky
    Aky Aky
    1,512
    Have you checked to make sure it isn't spraying into the boot. The pipe comes off the sprayer. I had my boot sensor replaced 4 times because water had shorted it out.
  4. danotto
    danotto VAG HUNTER
    1,090
    couldnt see any water in the boot,it is coming out of the washer jet but it dribbles out all prob get that repair kit,have you got the part number jester,
    Thanks for your replies i appreciate them:respekt:
  5. Spacecowboy
    Spacecowboy Member
    367
    Is it coming out ok in the front jets? If not, run hot water throught eh system and spray. Some cheaper windscreen wash (or no fluid at all!) gets real thick after a while and starts to resemble jelly...
  6. simch
    simch Active Member
    2,028
    Isn't there some filters on the washer bottle? Seperate for front and rear....?
  7. danotto
    danotto VAG HUNTER
    1,090
    fronts work fine,just the rear thats playing up,i know most washer bottle have gauze filters to stop **** getting throgh to the washers but didnt know the front and rear had individual filters,cheers again guys
