Rear wash wipe removal audi a4 avant 2004
pgy531 Aug 7, 2010
  1. pgy531
    pgy531 New Member
    19
    Hi All
    Does anyone know how to remove the rear was wipe on an audi a4 avant 2004.
    There is a piece of plastic that has snapped or has worn at the rear of the wiper the bit that makes it spring back with pressure and I want to take it off an put a metal pin in its place.
    Any ideas greatly accepted:readit:
  2. Jimmeh
    Jimmeh Active Member
    1,438
    Ive just done this; remove the inner trim on the bootlid and you should be able to locate the (x3?) 10mm bolts. Pretty simple after that. (hardest part is removing the trim pannel!!)
  3. pgy531
    pgy531 New Member
    19
    I've tried removing the inner trim, four screws and it pulls down to a pint but there is somthing holing the trim in place!
  4. pgy531
    pgy531 New Member
    19
    did yours have the same issue, no spring back?
  5. quattrojames
    14,060
    583
    Its been done before HERE and how to remove the trim is detailed HERE
  6. pgy531
    pgy531 New Member
    19
    It seems I was barking up the wrong tree, The arm of the wiper is U/S so I,ve managed to prise off to have a look, as per all audis its a piece of plastic that has worn, hence no spring back on the rear wiper, you don't happen to know the part number for the wiper unit do you?
