Rear vs. front tyre wear
jcs356 Mar 5, 2006
  1. jcs356
    jcs356 Brum brum
    2,734
    70
    Had my car MOTd today. Comments from the tester was I had 2.5mm tread on the rears, but 4mm tread on the front, with all four tyres showing even wear across the tread (tyres are Bridgestone Potenza RE050A). All four tyres were change at the same time (approx 15,000 miles ago), and they've not been rotated since new.
    My query is how come a 'predominantly' front wheel drive car has ended up wearing the rear tyres more than the fronts. It the wear was uneven across the tyre, I would put it down to incorrect rear suspension settings etc, but to wear the rears evenly across the tyre more than the front seems strange to me. Any thoughts? Thanks.
  2. jojo
    29,001
    3,657
    My S3 wear the fronts down quicker for definite, so I have rotated them, the inner edges are also wearing slightly quicker since fitting lowered suspension. /ubbthreads/images/graemlins/smirk.gif
  3. darnich
    darnich Member
    106
    perhaps you use the handbrake too often /ubbthreads/images/graemlins/smile.gif
  4. chippie
    chippie Member
    91
    sounds strange, mine wore slightly more on the front but only by a small amount as u would expect
  5. Rev-head
    Rev-head Active Member
    2,987
    Thats mighty strange...........did you check that they had not made a mistake and it was your front tyres?
  6. s3bow
    s3bow Member
    381
    Quite the opposite with mine Jo. Both my S3s have worn the rears faster than the front. Put it down to the negative camber.
    Chris.
  7. darko
    darko Member
    272
    the rears on my S3 also wear much faster than the fronts...
  8. jcs356
    jcs356 Brum brum
    2,734
    70
    Thanks guys - so it looks like a couple of you have had the rears wear first so it isn't just me or my car!
  9. jojo
    29,001
    3,657
    Maybe it's a case of different driving conditions, rear wears out quicker for long distance driving? I corner pretty hard with my car with my tyre pressures set at 35F/39R
