Rear Tracking
dublinS4 Oct 11, 2013
  1. dublinS4
    dublinS4 Member
    53
    Dropped the S4 in for 4 wheel alignment the other day.. They couldnt adjust the rear camber. Said the bolts were running freely on one of the arms used to adjust the camber.. Tow was fine. They told me i have to replace the rear arm... Question is what one???
    Any help would be great lads
  2. spartacus68
    spartacus68 Active Member
    160
    35
    As you would have it - my 2.5 quattro avant has had the same thing done recently Rear tyres were wearing on the inside tread. Mechanic said rear toe adjustment was seized. However I'm £380 poorer as a result. Told the mechanic that it wasn't essential to fit Audi parts (car on 152k) and parts cost £190! I'll post pictures tomorrow.
    dublinS4 likes this.
  3. aragorn
    18,665
    880
    Your description of the fault doesnt really make any sense.
    The camber is set by an eccentric bolt in the lower wishbone. Not sure how this could fail?
  4. dublinS4
    dublinS4 Member
    53
    Just relaying what this fella said to me.. What do i need to replace if my rear camber cant be adjusted?
  5. aragorn
    18,665
    880
    I really cant say without seeing it?
    It could be that the bolt is siezed?
    I guess it might be possible that the channel the eccentric washer sits in has somehow worn away or come off, but it seems unlikely. Can you take a photo of the lower wishbone in question?
    I think i have a spare pair of wishbones in the garage if you need them. You might want to take the opportunity to fit new bushes into them though.
  6. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    I had a the washer on the bolt bend outward when they tried to adjust it, and on a new Audi supplied washer the tag snapped off.
    The camber is on the lower wishbone, easily seen looking under the brake caliper area.
    I had a problem with my toe setting - on both cars the bolts were seized solid and took a lot of work to replace (See here)
    It is well worth dong properly - the difference can be amazing.
  7. spartacus 68
    spartacus 68 Active Member Team Ibis quattro Audi A2 Audi Avant Owner Group
    405
    66
    My new rear arms. Judging by the labour charge - it was a pig of a job.
  8. dublinS4
    dublinS4 Member
    53
    Where did you buy them and what was the cost of the arms?
  9. aragorn
    18,665
    880
    Those arms set the toe, not the camber.
  10. spartacus 68
    405
    66
    Mechanic would have ordered them from trade supplier, (they're Delphi). They were eye-watering £120, eccentric bolts and washers just under £20, plus re-alignment £40, plus labour.
  11. PAULF
    712
    66
    Try All German Parts.
    I did all of my bits on both cars using Meyle/Lemforder but can't tell you the price as I got front and rear arms and bushes!.
