Rear Tie Bars
Sidey Jan 22, 2013
  1. Sidey
    Sidey Active Member
    285
    153
    43
    Can anyone tell me what metal the rear tie bars are made of? Mild steel maybe?
  2. <tuffty/>
    21,356
    3,923
    I would imagine so... they won't be stainless...
  3. Sidey
    Sidey Active Member
    285
    153
    43
    Deff not with the way they rust and snap lol
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    yeah just mild steel.....:icon_thumright:
  5. Sidey
    Sidey Active Member
    285
    153
    43
    Thank you, converting my stock ones into adjustable so wanted to know what steel I need to have machined.
  6. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,178
    215
    Group buy? :)
  7. dancupra225
    dancupra225 Active Member
    667
    25
    I have spare ons in the shed if need spare ones
  8. Sidey
    Sidey Active Member
    285
    153
    43
    That would actually be awesome, but I am sure you are thousands of miles away :3sadwalk:
  9. ShaunS3
    1,178
    215
    Spare adjustables in stainless? :)
  10. lloydie1
    lloydie1 Member
    68
    Stainless has a lower tensile strength than mild so you're actually MORE likely to snap a stainless bar. That being said the bars dont snap 'by themselves' there is always a contributing factor such as the bush they bolt to seizing.
  11. Schlaag
    Schlaag Bwah
    472
    32
    A bit off topic gents, but what does the tie bar mount to on the chassis of the car?
    If say.. oh I dont know.. a hit and run driver , smacked in to my rear passenger wheel, head on... could the impact push the tie arm 'back' and bend the mount? as the arm itself has not bent.... as far as I can see
  12. <tuffty/>
    21,356
    3,923
    Fixes to the rear subframe which in turn is fixed to the body.. the subframe is pretty sturdy so the arm would suffer first...
  13. RobinJI
    RobinJI Active Member
    178
  14. <tuffty/>
    21,356
    3,923
  15. RobinJI
    178
    Tuffty, not sure if that's aimed at me, but just for clarity, my post was meant for the original topic poster, he mentioned getting something machined ("wanted to know what steel I need to have machined"), so I was just linking to parts he may be able to use to save the hassle/expense.
  16. <tuffty/>
    21,356
    3,923
    Ah yeah... without a quote the context was lost... soz..
  17. superkarl
    superkarl MAN OF STEEL
    9,494
    2,436
  18. RobinJI
    178
    Yeah, my bad, I wasn't very clear about that. The arms look simple enough to modify, shouldn't be too hard to do at all. Am I right in thinking that it's the bush in the hub seizing that causes all the issues with them breaking? If so then I think I'd be placing the adjuster as close to the chassis end as sensible to keep the leverage on it down should the bush bind. That should help minimize the issue with the weakening caused by the HAZ too, in fact I'd be tempted to sleeve and plug weld the threaded inserts in to help with that.
  19. g60leigh
    g60leigh Well-Known Member
    1,674
    207
  20. dancupra225
    667
    25
    No lol i can always post them etc
  21. Platty
    Platty New Member
    Not Audi ones......These are what I have on the rear of the MINI.
    One of my lower arms snapped a couple of weeks ago.......
    I was bloody lucky in that it only happed 50yrds from my house on the way home from work. I drive nearly 60miles a day on bumpy, windy B roads......I'm not known for hanging about either.
    How much are replacements these days? Is it worth going aftermarket on a daily? I've slung on a 2nd hand jobbie at the moment.
  22. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,209
    2,029
    If you are not lowered then oem is suitable
