Rear suspension bits
tdia4 Jan 18, 2011
  1. tdia4
    tdia4 TDIPOWARRR
    613
    Picking up a lowering kit on Friday and will be fitting it soon, just having a look through the Haynes Manual and it says when you change the rear suspension your should replace a gasket that goes onto the strut upper mounting.
    Has anyone got a link where I can get these online? Also going to replace the rear lower mounting bolts, again any help where I can get these? It then also says to replace the upper mounting bolts????? Should I? Can't see them being in bad condition.
  2. tdia4
    tdia4 TDIPOWARRR
    613
    Anyone?
  3. nwmlarge
    nwmlarge flat out
    219
    its normally a bit of paper. just use a bit of paper or card roughly the right shape.
  4. tdia4
    tdia4 TDIPOWARRR
    613
    Ok cheers buddy, also what about the rear lower strut mounting bolts? Searching everywhere with no luck.
  5. aragorn
    18,297
    804
    Bolts like that are typically dealer only. I'd just reuse it.
  6. tdia4
    tdia4 TDIPOWARRR
    613
    Got a couple of places on the case for me now, if non on them come up with anything there getting reused.
  7. tdia4
    tdia4 TDIPOWARRR
    613
    Do you think a VW garage would be able to help me get these bits? Got no Audi garage near here, nearest one is like 50mile away.
  8. pjw
    pjw Member Audi A4
    222
    Just reuse them?
  9. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    I get most of my parts from VW.
    They wont sell me any Skoda parts or do any servicing work though :(
    Reuse them, unless they damage or the heads are rounded off.
  10. nwmlarge
    nwmlarge flat out
    219
    yeah vw will supply no problems.
    i don't know what year yours is but mine had elongated bushes at the bottom of the strut so i had to cut a section of the bush to pack it out.
  11. tdia4
    tdia4 TDIPOWARRR
    613
    Was that just for the coilovers?
    Im getting sport struts with lowering springs.
    Think i'll pop down to VW and see if they can help with the parts.
  12. nwmlarge
    nwmlarge flat out
    219
    i can't say unless you get a pic of the lower mount point
  13. aragorn
    18,297
    804
    VW will only sell you it if its also used on a VW model.
    IE if the bolt is ONLY used on an Audi model, then the VW garage wont be able to order it.
    I've had this a few times, went in with a list of random bits and bobs, most of it was fine as the engine/transmission/front suspension is all shared with the passat, but the rear end is pretty specific to the A4, and the caliper bolts werent available to him, and i had to order them from preston audi.
  14. tdia4
    tdia4 TDIPOWARRR
    613
    Got priced up for all the bits from StokeAudi, just waiting for them to get back to me on how to pay because non of the parts are on the website.
  15. I buy most of my bits from VW too, right next door to Parth Audi, but when you can save on a battery Audi 82Ah @ £117+vat against VW 85Ah @£75+vat, the only difference being a sticker and an extra 3Ah.
    Just bought new brake hoses at VW last week.
    Perth VW will supply Skoda parts too now, there is a Skoda dealer 10 miles form Perth tho
