Rear subframe
S3Zek Apr 1, 2012
  1. S3Zek
    S3Zek Member
    410
    Evening all, I was messing about doing a four wheel alinement on my s3 saturday as ive dropped it a bit more and I couldn't get enought adjustment on the toe on the pas rear, it is out as far as it can go like the other side and is still at 0.40 when it wanted to be at 0.07ish so then noticed that the rear left sits out about 10mm more then the right, the car is straight and has had no smash ups but it's as if the rear sub frame needs to go over by 5mm, I know it has had work on the back by Audi before so I may have been dropped down before, do you think there is enought play to loosen it and shift it over or are they ment to be slightly offset?
