Rear Speaker Help Pls
Tooand Jan 6, 2013
  1. Tooand
    Tooand New Member
    Hi I fitted a new Sony head unit to my 1999 A4 saloon non-Bose,as the old unit was looking dated(it was also an aftermarket HU). I have never had sound from the rears so came on here for help and found all I needed was a PS9- 404 to fix the problem, but it hasn't. If I fade all the volume to the rears you can just here it so there is something there, have I not done something right I'm baffled
  2. Tom_B
    Tom_B Member
    296
    20
    The rear speakers are powered by the little amps built into them so they are wired at line output level. I wonder if the previous owner has changed the wiring somehow.
  3. AndyMac
    9,832
    45
    You will have to fade to rear quite a bit to balance the sound as the rear amp is only 2 x 20w and the new HU will be chucking out over twice that power to the fronts. Far better to rewire the rears directly to the new HU and just bypass the hopeless rear amp.
    Have you connected the blue flying lead on the PC9-404 adaper to the power antenna 12v output on the new HU? This is the trigger to turn the rear amp on, without it the rear amp won't turn on.
  4. Tooand
    Tooand New Member
    Thanks for the response guys, I have plugged the blue amp wire from the HU loom to the blue wire on the pc9 404 one had a male end and the other female so presumed they went together, I do have a lighter blue wire for the aerial coming from the HU, does that need to be connected, like I said I do have sound from the rears but very quiet and bassy
  5. AndyMac
    9,832
    45
    As said you need to rewire the rears directly to the HU
  6. Oranoco
    Oranoco Well-Known Member
    3,861
    381
    As has been said mate you need to run a new set of wires straight from your new HU to the speakers.
  7. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
    before wiring the rear speakers direct to the HU, it may be worth sticking a meter on them and measure the impendence.
    My full bose has 2OHM speakers, which if powered from an aftermarket HU, will burn its internal amp out. Aftermarket HU's are designed to work with 4OHM.
  8. Oranoco
    3,861
    381
    Pretty certain only the Bose units run at 2ohms. I pulled out my factory rears and fitted a set of old Kenwood Dualmags from my old Fiesta.
  9. AR-rkon
    1,913
    165
    I think it is only the Bose, didn't want the OP to blow his stereo :lmfao: god knows I did it first time round haha
  10. Tooand
    Tooand New Member
    Well I solved the problem, I bought another car. Another 2.8Q but automatic this time, it's fitted with a Bose Symphony system so I've got plenty of speakers in this one(this wasn't the reason I bought it, just fancied a change and an automatic). Thank you for all the help though
