Rear Shocks
audi18tdan Aug 11, 2009
  1. audi18tdan
    audi18tdan Member
    241
    Currently looking into replacing the rear shocks to complement my lowering springs as i believe the offside rear is fooked and wanted peoples reccommendations on a budget.
    Also if anyone has any shocks (dampers) for sale let me know
  2. fingermouse
    fingermouse thats me
    4,003
    112
    do it once do it right Billys all the way
  3. <tuffty/>
    21,356
    3,923
    Billys FTW +1
  4. audi18tdan
    audi18tdan Member
    241
    what's so good about bilstein's?
  5. ash_pearce
    ash_pearce Member VCDS Map User
    321
    more the point whats not good about them?!
  6. fingermouse
    4,003
    112
    They work well and last, you can fit others but you will always be lacking lol
  7. Andy_S3
    Andy_S3 Member
    722
    Just had these fitted mate, and rate them highly, but to be fair I dont know how they compare to cheaper alternatives.
  8. mattyboy199
    mattyboy199 Well-Known Member
    1,897
    30
    are the rear shocks easy to replace yourself ?
  9. audi18tdan
    audi18tdan Member
    241
    Hi,
    which ones exactly?
    May get Weitec GT shockers
  10. alijames
    alijames Active Member
    1,024
    On an S3, yes. Took me ~20mins per side.
    Fronts are more of a pain, as they are struts, so have to be removed.
    Cheers,
  11. M15ley
    M15ley New Member
    14
    Only 20 mins each?!?! That sounds quick and easy, whats actually involved?
  12. alijames
    1,024
    If I recall correctly,
    1. Jack up the car, put on stands and remove the rear wheels.
    2. Put trolley jack under hub to support once shock is disconnected.
    3. Undo top and bottom bolts of shock mount.
    4. Remove old shock, and install new one, making sure the bolts don't cross thread as I nearly did!!
    5. Torque up bolts. Sorry can't remember the settings of the top of my head.
    6. Refit wheels and get the tracking checked ASAP!
    There is an article about changing suspension on a Mk4 golf at
    http://www.nclh.org/car/coilover_howto/
    which is where I got most of my info from. The fronts are pretty much as he says. The S3 has a slightly different rear suspension layout, due to the Quattro system.
    Think that's all...
  13. audi18tdan
    audi18tdan Member
    241
    Right, i do indeed need new rear shocks now after confirming the offside rear is badly designed and rod pushes past top mount.
    So which dampers, need to order today???
  14. alijames
    1,024
    Best speak to Damian at DPM...
    Cheers,
    Alistair
  15. audi18tdan
    audi18tdan Member
    241
    Oh yeah forgot about Damian.
    Anyway originall ordered a set of Koni Sport rear dampers which are top adjustable which is great but spoke to Venom and they are out of stock so got some Spax ones instead which are bottom adjustable which is even better.
    Should arrive tomorrow
