rear sensor audi a3 sportback 2005
tanjawi Mar 24, 2013
  1. tanjawi
    tanjawi Member
    54
    hello there
    got a probleme with rear sensors of Audi a3 2005 they dont work any more
    but when i engaged the gear to Reverse it just making a sound and that is it ?? any ideas guys ?
    cheers
  2. NHN
    29,331
    1,716
    The sound is a long beep I assume which indicates a fault in the system, could be a sensor down or the loom, needs a scan to check fully tbh, whereabouts are you?
  3. tanjawi
    tanjawi Member
    54
    from county durham
    yes exactly what u said it is a long beep and thats is
    how can i fix that please
    many many thx in advance
  4. tanjawi
    tanjawi Member
    54
    hello
    my car Audi a3 2.0 Tfsi sportback 2005/55
    got 2 problems
    1 - No security system beep when vehicle is locked or unlocked
    2 - Rear Sensors Doesnt Work Any More Just Making Long Beep About 3-5 Second When i Engaged To Reverse and Thats It
    Thanks In Advance
  5. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Alarm beep can be turned on or off with vcds, do the hazards flash when its locked/unlocked?
    Dont know about the other Q though.
  6. NHN
    29,331
    1,716
    Please don't open multiple threads on the same subject, it just makes things messy, any additional info needs to be added to your existing thread.
  7. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,653
    9,645
    ​Have you had the car scanned with vcds and where are you located? :) x
  8. Sandra
    26,653
    9,645
    Threads have been merged, please dont start multiple threads on the same subject. If all the information is kept to one thread it will then be more accessable and useful to others at some other point. Thank you
  9. tanjawi
    tanjawi Member
    54
    No I didn't scan the car yet will be expensive to fix this problem tho ?
  10. amit87
    amit87 Active Member
    172
    78
    no one knows what the problem is to quote. It could be a coding fix which is £free if you have or know someone with VCDS, if the can gateway is faulty, that is around £170ish from Audi I think.
    Basically cant put a price on it unless we know what the issue is and we wont know till its been scanned with VCDS unfortunately.
    A cheap and poor fix would be to buy a cheap universal reverse sensor kit off ebay (but if you was willing to go that route, doubt you would have brought an Audi haha)
    get it scanned is my advise and most likely everyone else's too im afraid.
    Also if you go to a garage, most usually charge an hours labor for the use of their diagnostics machine. (even for 10mins use, unless you know them or they are kind)
  11. tanjawi
    tanjawi Member
    54
    Hopefully there is not something bad
  12. Sandra
    26,653
    9,645
    Check out the vcds map for a user near you.
  13. amit87
    172
    78
    Hopefully but the way these cars systems are integrated, could be a 101 things that could cause an issue, hence the VCDS scan being important as it narrows down what the issue could be if not specifying the issue.
  14. tanjawi
    tanjawi Member
    54
    Yeah will do that in morning cheers
  15. tanjawi
    tanjawi Member
    54
    I don't think will be something bigger than a code don't know
  16. NHN
    29,331
    1,716
    Just get it scanned as advised, no point trying to guess the cost is there, when we have no ideas what's wrong with it.
    It wont be gateway as it still beeps, which means its communicating around the car ok.
