Rear seats wont go down
LoopTrooper Apr 25, 2012
  1. LoopTrooper
    LoopTrooper Member
    Just bought a 5 door TDI and I would have assumed you just pull the flippers at the top of the seat and push it and the seats would go down. But this works on neither of them.
    Any suggestions on how to get them working? I got as far as shaking them violently and swearing..
  2. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Brute force is the only way when it gets stuck.
    ..use one hand to hold the flipper in the release position and with the other give the back of the seat a hard thump shouting "YETI OVER!!!
    That should do it ;)
  3. Cobra88
    Cobra88 Active Member VCDS Map User Audi A4 Audi Avant Owner Group TDi
    553
    70
    My original seat used to stick on the passenger side
    a small screwdriver inserted near the catch and pushed upwards did the trick ;)
  4. damo.h
    damo.h DVLA Say it's Black
    3,610
    67
    Pmsl @ Yeti over
    Get the misses to hold the flipper go around a boot the fk out of it.... Hopefully you'll take em both out with one kick !!
  5. Mine used to get stuck a lot!
    I ended up taking the parcel shelf out, kneeling down in the boot (as you do) and pulling the lever while barging into the back of the seat. Quite amusing when it finally goes!
    Just just spray some GT85 or something similar on the catch and a tiny bit of grease on the........U Joint? mine hasn't stuck since!!
  6. LoopTrooper
    LoopTrooper Member
    Gonna have to get my violence on. I know I will start by trying to prise it with a screw driver but for some reason violence always seems to be the answer.
  7. LoopTrooper
    LoopTrooper Member
    So met a few friends last night so thought it would be the perfect opportunity to try some brute force. One pulling and three pushing and the seats came down no bother...
  8. sportstractor
    sportstractor Chugger
    2,709
    yep, same here, requires a heavy foot from time to time
  9. damo.h
    3,610
    67
    Lol it's like one of them jokes. How many VAG drivers does it take to fold the rear seats? One to hold the the knob and three to bang fk out of the rear ;)
    Taxi for one :undwech:
  10. AJD S3
    AJD S3 2nd Gear
    107
    15
    They seem to get stuck all the time, as the gap created by the catches seems to reduce over time, until they just stay stuck.
    I have to put my seats down fairly regularly, and after them getting stuck for about the millionth time, I decided it was time to get a proper method together to getting them down, and so, after much experimentation, swearing and cursing:
    - hold the release lever in with one hand
    - raise the head restraint up with the other so there's enough room to grip one of side of the metal struts
    - with a firm grip on both, sort of 'wobble' the seat from side to side whilst pushing forward.
    There's an art to this method, but seats always go down very quickly and easily using it :)
    But if this doesn't work for you, for whatever reason, go for Maz's method:
    There's something in those words, 'YETI OVER', just makes it work. Might have to start saying it when putting mine down to speed up the process...
  11. LoopTrooper
    LoopTrooper Member
    I've left the seats down for now. When I go up the garage I will grease everything up and hopefully it'll stop it from getting too stuck again. The triggers seem a bit sticky anyway so just seems like something needs greasing.
