rear seats soaking wet
dancupra225 Feb 15, 2013
  1. dancupra225
    dancupra225 Active Member
    667
    25
    went out tonite and pick up some friends up and one shouted my ass is soaking wet pull over and the rear seats are soaking!!!
    how can this happen??
    the rear bit of boot isnt wet just cant work out where it is coming from???
    anyone else had this problem??
  2. westers
    westers New Member
    19
    What age and model of car? Number of doors, etc, etc
  3. dancupra225
    667
    25
    2004 plate 3 door audi a3 8p as its in the 8p section
  4. NHN
    29,300
    1,703
    Not helping yourself with that reply, diesel or petrol, engine, year, 3 or 5dr, etc etc all these things are relevant, so for future reference, please provide the info :)
    Assume its water, any water stains or wetness in the headlining?
  5. dancupra225
    667
    25
    Wasn't being funny,
    2.0 tdi 140bhp
    Rear headlining is dry just the Rear seats both sides just really strange
  6. NHN
    29,300
    1,703
    Ok so its just the sides or the whole bench is soaked?
    Is there any signs of water ingress around the door openings?
    Has it been raining where you are?
  7. westers
    westers New Member
    19
    Not being funny, but are you sure your guests didn't pee themselves?
    RYes3 likes this.
  8. NHN
    29,300
    1,703
    Given how late this was posted, maybe it was, urggghhh, the thought of it.
  9. AndyA3170
    AndyA3170 Guest
    I was thinking the same strangely enough lol. I'm wondering if you've had pee pee time passengers.
  10. dancupra225
    667
    25
    No all sober its water as took the seat out only pláče i can see water from.boot so going get someone to spray water on Rear on car later
  11. Ash187
    7,471
    731
    My gf had something like this where the rear footwell would be wet after it rained and turned out that her rear brake light was not fitted on tightly enough and water was leaking in through there and soaking the back of the car
  12. dancupra225
    667
    25
    Going to check.everything today get the problem really bad Hate things i cant find
  13. westers
    westers New Member
    19
    It could be rubber seals around the windows..maybe.
    Did your mates have any bottled water with them? If so, they could be having a laugh at your expense, and they poured water onto the seats.
  14. jimmo
    jimmo Member
    81
    I had a similar thing with an old Renault hatchback. Water ingress through duff seals running along the floor of the hatchback, down behind the seats to the footwell. Worth checking the rear and tire well, as well as the footwell for dampness.
  15. dancupra225
    667
    25
    Well took seats out use my water sucker mother has worked well
    Dry it all out by the heater over night seems to be fine hopefully leak is no.more
    Sorry about other post im dyslexic i miss words out alot
  16. The Governor
    The Governor Active Member
    526
    75
    I've highlighted the bits of your post that I didn't understand in bold text.
  17. Artimus
    Artimus Shortback
    2,012
    482
    does the rear screen washer work with the same pressure it previously has? if not, the pipe may be split or disconnected - leaking water into the interior. Failing that my money's on a rear light cluster leaking.
  18. dancupra225
    667
    25
    Well washed her today no.leaks using pressure washer so.looks like fixed the problém
  19. audicruiser
    audicruiser Audi Heaven
    1,865
    As said, I would check your rear washer...
