Rear seatbelt removal
Ads Mar 15, 2010
  1. Ads
    Ads License to drive
    8,230
    608
    Anybody know how to remove the nearside rear seatbelt on a 3 door??
    Had a quick look but it looks totally hidden away behind the trims.
    Is there an "easy" way to remove???
    Also, the reason I need to get to it is because the seatbelt has decided to stop retracting. I can get it to retract if I fiddle with it for some minutes, but I'm losing patience with it now.
    Are these things generally fixable, or is it a case of when they're gone they're gone!?
  2. h5djr
    9,438
    1,757
    Here is a page from Elsawin showing the removal of the rear seat belt in a 3-door. Hope it helps.
    rear seat belt - 3 door
  3. Ads
    8,230
    608
    Thanks Dave.
    But.............................. :scared2:
    I've got to remove the back seats and boot carpet and trims and basically the entire back of the car, just to change a seatbelt! :faint:
  4. Lex
    Lex Member
    365
    its honestly not that bad to do
    it all comes off quite easily and can be done in about 20mins
    i had the same problem with my seat belt, a little white plastic clip fell out and it stopped retracting properly and the cost of a new seat belt is alittle annoying
  5. Ads
    8,230
    608
    Cheers mate, I might give it a crack later then.
    Hopefully it can be fixed. Noticed the cost of a new seatbelt and you're right, it ain't cheap.
