Rear seat not locking
TwedA4 Dec 20, 2013
  1. TwedA4
    TwedA4 Member
    111
    hi guys,
    got a bit of a problem with the larger half of the rear seat in my avant not locking into place... i've tried slamming it into place and even pulling hard against it from the boot and it just wont lock. it just bounces back. i've poked a screw driver in the lock and it locks fine, not sticking or anything. and the locking pin is in line with the catch, but it's got me baffled...
    anyone had any similar problems?
    stu.
  2. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    never experienced this personally, but have you checked down the sides that there is nothing jammed in there, stopping the seat back from returning to its home position?
    if there is something there this will stop it! i have to slam mine in order to close properly so orange tabs are not visible and showing open, so if something is in there, then it will never lock!
    hope this helps! try using a torch down the gaps!
  3. quattrojames
    14,050
    574
    You could try adjusting the 'pin' end of the latch mechanism. It screws into the side of the car with a large (17 or 19mm..) I think ring spanner. Pull it back a bit and I'm sure it will latch then.
  4. adcooper
    adcooper Audi A6 C6 Avant 3.0tdi Le Mans S-Line
    319
    9
    I had this issue when I changed to Recaros, I managed to fix it using a screwdriver in the lock mechanism locking and unlocking it fully and a bit of WD40 "or similar" , give it ago.
  5. TwedA4
    TwedA4 Member
    111
    cheers guys, i'll give it a shot.
    and i never actually thought of checking if anything was stuck in it... lol
